Cully's Bianca 6 R150 YVM
#91
droplinks.......................Done
handbrake cable............Done
Steering rack gaitors......Done
Lamps..........................Done
Cambelt.................they sent the wrong water pump........nearly done
garage bill paid!
Beam......delivering car monday morning
Big Grin
yay! Big Grin
Are they white turinis its on? Fancy a swap ninja
(03-05-2013, 06:06 PM)Niall Wrote: Are they white turinis its on? Fancy a swap ninja
white turinis with 4x 2week old Kumo tyres Big Grin
a swap let me think about it............
LOL!
gunmetal turinis would look great on that!
may go out the garage tomorrow and have a go at cleaning the paintwork up and give her some wax on wax off Wink
as ive managed to get a bag of face cloths for cleaning her
i was going to do a lot of things today but as usual work had other ideas as ive been called out!
when and saw the car it was on the ramps so took a good while looking at the underside for problems
only found 2 scabs of rust wire brush and a paint will cure that before it gets out of hand
also think the crank flywheel oil seal is leaking as theres a little oil around there
may explain the slippy clutch report
pictures we all like pictures
new cambelt and water pump
shitty air filter
oil leak
Meow less
long wheel bolts
Fixed
New arch linner needed
rust 1 and 2
pinned cam pulleys
Looks lovely mate. Will look schweet by the time your finished. Keeping it oem+ like the hdi?
Really like this, will be a proper decent motor when your done Smile
getting itchy feet now!
i want to drive it again,
the sound driving over the moors coming home was Epic!
there are some lovely twisties on that A396 between Tiverton and Dunster
and the drive home with it on the B3190 was magical Big Grin
Looking good Cool
hmmmmmm tinted rear lights D:
good progress though! Making me want a 6 even more now that i know a fellow diablo hdi estate owner is enjoying one so much!
Bout fecking time you came over to the fuel of gods lol
Looks a cracker bud!
[Image: SDC10442-1.jpg]
delivered this for its beam recon today
so its the garages first job tuesday
guy tryed to talk me out of reconing the beam to the lowered position saying it put stress on the shafts
told him to mirror the lowering as on the car now which hes going to do
this is all this guy does recons beams, the yard was lined up with beams
....WANT TO DRIVE IT NOW! I SAID NOW!!!!!!
moved the drive around, need to get a new gate, fitted another CCTV camera.
guess whats going in the empty space on the drive!?
gosh you have been a busy boy.
looking good Paul, i have PM'd silverzx regards boot lock motor so fingers crossed Wink
[Image: siggy1.jpg]
Does the wheel even turn with those bolts in?!
Car looks fantastic though!
yes the wheels do turn i believe the fronts have been cut down though!
so i guess one of my first jobs is to cut match all the bolts to the same length so they can be swapped around without causing damage
also check if the bolts fit the spare.........come to think of it ive not seen the jack or brace
where is it hidden on a three door??
(06-05-2013, 06:13 PM)cully Wrote: moved the drive around, need to get a new gate, fitted another CCTV camera.
Some perdy flow pots??
Got a couple of OE air boxes here if needed paul ThumbsUp
Where the vin plate is in the boot they should be next to the os rear light!
Did you go with SPP Engineering for the rear beam in the end then? Be good to know somewhere localish in case mine needs doing.
[Image: sigjpg.jpg]
Serious.
(07-05-2013, 07:50 PM)lewisdmz Wrote: Did you go with SPP Engineering for the rear beam in the end then? Be good to know somewhere localish in case mine needs doing.
yes it is there as we speak i delivered it on bankholiday monday
i suspect il get a phone call tomorrow fingers crossed
I hear they've got quite a good reputation up there, its owned and run by my mates grandad lol
Are they the 1s at stockland?
They are mate
Paul can you pm your address to silverzx so he can post the boot lock motor out to you? Smile. Its From a ph2 DT but I guess they are all the same?
[Image: siggy1.jpg]
(07-05-2013, 10:48 PM)devils_fuel Wrote: Paul can you pm your address to silverzx so he can post the boot lock motor out to you? Smile. Its From a ph2 DT but I guess they are all the same?
What he said.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
oh dear.....
im ordering parts from peugeot for it already and ive not got the car home yet!
1327.34 O/s rad top clip £3.67
1327.40 N/s rad top clip £4.42
0349.G1 inlet manafold gasket £4.01
1635.C3 inlet butterfly gasket £1.72
didnt realise pug parts were so cheap from the stealers
Almost an identical list of what i bought last week lol
  cully's XU10J4RS cully 11 9,484 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 90,610 16-04-2016, 04:14 PM
Last Post: cully
