05-04-2013, 02:57 PM
not sure if its normal but when releasing the clutch it seems to judder slightly its had a clutch done so dont think it that
clutch judder
05-04-2013, 03:01 PM
only noticeable really taking off?
my 406 does it too, i just ignore it, think it may be warped flywheel but not that bothered to fix it..
05-04-2013, 03:04 PM
Mine does the same
was actually gonna ask as well lol
05-04-2013, 04:00 PM
I fitted a Valeo clutch the other day to my 306 XUD and it still judders when setting off, not too bothered by it. I think its just an XUD thing!
05-04-2013, 04:12 PM
top engine mount is gone in mine now you mention it, its nother job on the back burner..
05-04-2013, 04:29 PM
ah cheers yer only when taking off if your real gentle it doesnt do it
05-04-2013, 08:06 PM
mine does the same doubt its the clutch as all my engine mounts are dead lol
05-04-2013, 08:28 PM
Funny I have this aswell, and just since I put my last engine in, notice it more if doing a hill start
05-04-2013, 08:47 PM
Yeah nothing in any other gear except first even reverse is cool
05-04-2013, 09:20 PM
I might be replacing all my engine mounts over the next few weeks anyway, I'll let you all know if it sorts it.
06-04-2013, 09:20 AM
Not normally engine mounts that causes this.
It's usually a flywheel that's gotten very hot and either warped or you've got clutch deposits ALL over it and it's causing it to skip. The other cause if you've gotten an old clutch is that the friction plate springs are getting tired/broken - will cause juddering as the clutch jumps back and forth with each pulse.
06-04-2013, 09:58 AM
(06-04-2013, 09:20 AM)Ruan Wrote: Not normally engine mounts that causes this. so i was right then. hmm, better sell it quick.....
11-04-2013, 04:35 PM
I'm gonna hold out till mot then maybe look at changing clutch
20-04-2018, 07:31 AM
