clutch judder - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: clutch judder (/showthread.php?tid=12539) |
clutch judder - ashkid - 05-04-2013 not sure if its normal but when releasing the clutch it seems to judder slightly its had a clutch done so dont think it that RE: clutch judder - sweeney1987 - 05-04-2013 only noticeable really taking off? my 406 does it too, i just ignore it, think it may be warped flywheel but not that bothered to fix it.. RE: clutch judder - Tyronnster - 05-04-2013 Mine does the same was actually gonna ask as well lol RE: clutch judder - Marcus1991 - 05-04-2013 I fitted a Valeo clutch the other day to my 306 XUD and it still judders when setting off, not too bothered by it. I think its just an XUD thing! clutch judder - Jonny b - 05-04-2013 Check your engine mounts lads RE: clutch judder - sweeney1987 - 05-04-2013 top engine mount is gone in mine now you mention it, its nother job on the back burner.. RE: clutch judder - ashkid - 05-04-2013 ah cheers yer only when taking off if your real gentle it doesnt do it RE: clutch judder - Dale - 05-04-2013 mine does the same doubt its the clutch as all my engine mounts are dead lol clutch judder - rickye - 05-04-2013 Funny I have this aswell, and just since I put my last engine in, notice it more if doing a hill start Re: clutch judder - Tyronnster - 05-04-2013 Yeah nothing in any other gear except first even reverse is cool RE: clutch judder - Marcus1991 - 05-04-2013 I might be replacing all my engine mounts over the next few weeks anyway, I'll let you all know if it sorts it. RE: clutch judder - Ruan - 06-04-2013 Not normally engine mounts that causes this. It's usually a flywheel that's gotten very hot and either warped or you've got clutch deposits ALL over it and it's causing it to skip. The other cause if you've gotten an old clutch is that the friction plate springs are getting tired/broken - will cause juddering as the clutch jumps back and forth with each pulse. RE: clutch judder - sweeney1987 - 06-04-2013 (06-04-2013, 09:20 AM)Ruan Wrote: Not normally engine mounts that causes this. so i was right then. hmm, better sell it quick..... Re: clutch judder - Tyronnster - 11-04-2013 I'm gonna hold out till mot then maybe look at changing clutch RE: clutch judder - mangler - 20-04-2018 (11-04-2013, 04:35 PM)Tyronnster Wrote: I'm gonna hold out till mot then maybe look at changing clutch Sorry, What was the problem? thanks! |
