Threads: 106
7
Car Model/Spec: GTi-6
Hi all,
I've fitted my A048R semi slicks back on today, and with all the extra grip they give, I've run into a bit of an irritating issue, that said, I did have it once or twice on the other wheels.
If I launch pretty hard, I get a clunk from underneath my feet - 1 knock.. that's it. If I then brake really hard, I get 1 knock. If I set of gently, no knock. It's like something is moving forwards and backwards.
Also, if I launch hard, I get a knock, then brake gently with no knock and launch hard again I still have no knock.
I have vibratechnics pbushes, and powerflex front bushes in the wishbones along with nearly new top mounts, vibratechnics engine mounts and a welded up (and substantially stronger!) top engine mount along with brand new track rod ends and rose jointed drop links.
I'll get underneath and have a poke about tomorrow, but what do you reckon? A balljoint starting to go?
JP
JP
Threads: 202
58
If you have a lower strut brace, check it's not whacking the bottom mount. Mine does this a fair bit.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Seems really odd in the fact that when it moves back and hits what ever it hits it stays there untill it forced forward again,
If it was the strut brace & mount it would hit it and move back as soon as the stress of the launch was gone, unless its the welded mount cousing it not to swing back but i doubt it, :S
Threads: 124
26
Car Model/Spec: Megane DCiR
06-03-2013, 06:43 PM
(This post was last modified: 06-03-2013, 06:44 PM by CJ_Derv.)
id probably say ball joint or elongated hole where ball joint goes, could possibly be track rod end worth a quick jack up though to check
check tie rods too as this was my problem before i got pissed off with it all falling to bits and put a fully built up subframe with all shiney parts tie rods the lot lol
Threads: 130
82
Car Model/Spec: 106 GO-NAD
I'm with cj, possibly the ball joint moving around in the wishbone
Had this with a number of ST tdci mondeos...
subframe bolts kept coming loose
There was a recall over it in the end.
Worth checking subframe bolts?!
Threads: 141
35
steering rack moving? as you say its coming from under your feet
Threads: 448
51
I had the same in my xsi, it went away after a while. So I pretended it fixed itself hahaha
Threads: 78
49
By after a while, you mean when you stripped it?
Threads: 208
60
Matt you really should be ban from owning any type of motorised vechicle
Threads: 92
43
Does it effect the steering? When my wishbone snapped at the pbush end, it would yank the steering coming on and off the loud pedal. A badly worn pbush would give the same effect (just not as severe lol)
Threads: 138
72
Car Model/Spec: Mincebus
I have this, also happens when reversing with the wheel turned to the left... I've changed the hub wishbone and pinch bolt. The track rod ends are also new (adjustable ones). Still can't work it out so was gonna throw it to a mechanic next week...
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 106
7
I'll take it to bits tomorrow and see what I find.. It's ever so annoying.
When you guys say tie rods, you mean track rods - right?
I'm 99% sure it's not the wishbones, but I guess it could be the balljoint / wishbone bolts.
I do vaguely remember trashing one of the balljoints with a hammer when me and Chris were whacking it in fitting it to the GTi... suppose it could be damaged.
I have also checked the subframe, got caught out there with my golf...
JP
JP
Threads: 124
26
Well youve got the tie bar which threads onto the steering rack whih has a bush on then your rod end screws into this mine had play on bush connecting to rack
Threads: 106
7
Ah ok, I've never taken one of those apart... can you replace the whole bar?
JP
Threads: 124
26
Yeah they just unscrew from the rack pal you cn usually tell if its this as it has play when jacked up
Threads: 106
7
No play at all anywhere Had it up in the air and can't feel anything... very odd.
JP
Threads: 198
135
My money's on wishbone bolts. Mine did this when the front bush bolt snapped, wishbone felt tight but the bolt had snapped in a really awkward way wedging it. It also meant a new subframe.. not saying yours is that bad but mine gave the exact symptoms as yours, if I were you i'd remove the wishbones completely to check them over.
Threads: 106
7
the front wishbone bolts are tight, nipped up properly... the back ones through the pbush are done up tight.
JP
Threads: 198
135
What i'm saying is mine felt tight, but out of curiosity I went to remove them and the front on one side was tight because it had twisted itself into the bush when it snapped, felt snug with an 18mm spanner but was truly f*cked up
Maybe you got a tool stuck somewhere?! or a loose spare wheel!?!
Threads: 106
7
Hmmm... worth taking them out to have a look.
Tool, no... spare wheel? C'mon!
JP
JP
Threads: 198
135
(07-03-2013, 03:08 PM)jammapic Wrote: Hmmm... worth taking them out to have a look.
JP
Exactly. Why fit a spare wheel when it obviously doesn't match the rest?
Threads: 124
26
07-03-2013, 03:13 PM
(This post was last modified: 07-03-2013, 03:44 PM by Piggy.)
no idea...but all this spare wheel talk aint helping jammapic
Threads: 124
26
(This post was last modified: 07-03-2013, 03:14 PM by CJ_Derv.)
(07-03-2013, 03:03 PM)Piggy1987 Wrote: Maybe you got a tool stuck somewhere?! or a loose spare wheel!?!
You wouldnt fit in his engine bay
Can of tyre weld
Or RAC number in my case lol
touche
Threads: 198
135
07-03-2013, 03:19 PM
(This post was last modified: 07-03-2013, 03:19 PM by cwspellowe.)
07-03-2013, 03:37 PM
(This post was last modified: 07-03-2013, 03:43 PM by Piggy.)
good point...now get back on subject you troller
