04-02-2013, 02:10 PM
As title guys, lookin at changing the oil on the 6 soon as its overdue, want something fully synth, any suggestions or reccomendations appreciated. Cheers
6 oil reccomendations
04-02-2013, 02:12 PM
Personally, I love the original total 7000 (think that's the one)
The car runs noticeably different on it, it's fairly cheap and Peugeot must of recommended it for a reason!
04-02-2013, 02:15 PM
(This post was last modified: 04-02-2013, 02:16 PM by Midnightclub.)
Ahh yes.. Yeah, I've heard its not too badly priced even from pug directly! Although i have a friend who works for pug.. Wonder if he can get me some discount..
Edit: I've found my current oil gets quite hot quite quickly when on a rag.. like 125 degrees
04-02-2013, 02:18 PM
Well mine will sit at 90 all day long unless I really rag it in which case it may creep upto about 100. Highest its ever been was 130 but in all fairness, I did spend a few minutes off the clock......I love living in a private road
04-02-2013, 03:48 PM
Nice haha, I'll have to price some up.. Although I've got the hdis oil to change first, fun times
04-02-2013, 05:32 PM
Slippery one
04-02-2013, 05:38 PM
I dunno, those VAG boys have been cleaning there inlets with sand.. i thought maybe some cement would do the sump some good?
04-02-2013, 05:45 PM
(04-02-2013, 02:18 PM)Niall Wrote: Well mine will sit at 90 all day long unless I really rag it in which case it may creep upto about 100. Highest its ever been was 130 but in all fairness, I did spend a few minutes off the clock......I love living in a private road Am I missing something? If you mean off the speedo clock, how the f*ck did you get there in your road? It's tiny!
04-02-2013, 05:47 PM
04-02-2013, 06:07 PM
Clearly vaughn you havent seen the 6 mile long straight that runs out from the turning area?
06-02-2013, 05:37 PM
I'm using Valvoline High Mileage 10W40, but here is a tropical country. The oil is good, helped keep in 90 car, but I do not know what viscosity recommend.
http://www.valvoline.com/products/consum...otor-oil/3
06-02-2013, 08:20 PM
Gulf Competition 10W40 - perfect for what a GTi needs, good detergents, fully ester synthetic, none of this "Fully Synthetic but actually made from mineral base stocks" crap...
I can't fault it... And in honesty, changing your oil isn't going to change what it's specific heat is... I.e. how much energy it takes to increase the temperature a given amount... That's relatively uniform across most oils... GTI6s do, when tuned have a bit of a reputation for eating big end bearings, so I would always use the best oil possible, the Total 7000/9000 I don't think is adequate really, for a STOCK engine used in a STOCK manner - fine, it'll do everything you need it to, but in extremes, it won't hold up as well as other oils which are a fairly similar price. |
