Airbag clock spring
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
Airbag clock spring
One of the casualties of my heater matrix change has been the airbag clock spring. I mistook part of the disc for a plug and tried to unplug it which resulting in it coming off and all of the tape going everywhere. I was looking at this for a replacement:
http://www.ebay.co.uk/itm/PEUGEOT-306-AI...2ec42c4225
It comes off a V veg I don't know if it will be compatible with the mark 1 airbag ECU or not.
I'd imagine it'd be different but can't say for sure. Surely the ph3 uses a 'better' airbag ECU to cope with the extra airbags. Correct me if I'm wrong but theres only one in ph1s isn't there?
There must be a part number on yours though, see if it matches the ebay one. I would think any replacement would have to be reset as well, maybe with PP or something.
doubt it will work. On the ph1s, the airbag controller is actually in the airbag in the steering wheel so i would of thought they are different.
And tom, if the ph1 is anything like the 2/3, the airbag system does a self check every start so doesnt need resetting with PP2000
(08-12-2012, 07:07 PM)Niall Wrote: doubt it will work. On the ph1s, the airbag controller is actually in the airbag in the steering wheel so i would of thought they are different.
Fair enough. I'm trying to use VAG knowledge with Pugs again and failing haha. Got my airbag slip ring/turn angle sensor (combined) on ebay atm and had a few people ask will it work straight off - but it seems it needs to be programmed by VCDS. I assumed Pugs would be the same, my bad.
The airbag controller is underneath the centre console on my oneUndecided But I have seen some on eBay which seem to be shaped to fit the steering wheel which is weird.
Either way the reason I am asking is because from what I can tell the clock spring is just a device to allow the electricity to pass to the airbag in the steering wheel but I wanted to be on the safe side.
Best bet is to check part numbers bud. Could be the same!
Does anyone know for sure or do I have to go on a scrappy raid?
Right, further investigations using servicebox indicate there are two types:
RPO07010
RPO07011
My old one has long been thrown out now so if anyone knows which one is fitted to phase 1 feel free to let me know!
Right, from comparing the squib for the 1996 and the 2000, the only difference seems to be the colour of the plug;
http://www.ebay.co.uk/itm/PEUGEOT-306-MK...4609769bbe
As you can see, the plug on the 2000 one is brown. But I don't know if the plug design is different or not.
  Airbag light still on after removing and reinstalling airbag 306Puggy 28 25,294 26-03-2013, 07:17 PM
Last Post: 3gan
  306 Airbag plus Clock Spring 306Puggy 15 9,435 14-01-2013, 12:27 PM
Last Post: Bananalad
  Tempurature clock to non temp clock Ben Jay 10 6,593 28-02-2012, 09:48 AM
Last Post: Foxy-jim
