Threads: 178
28
Car Model/Spec: HDi!
Do you have any dimensions mate? Gonna have a go at making something similiar out of a sheet of ali... Need to re route my battery for my scremer pipe, was gonna put it in the boot, but thats a much better idea!
Where did you get your mount from?
Threads: 541
124
That undertray is pretty well thought out, how is the bit near the exhaust coping with the heat?
Threads: 236
36
Looks like he retained the standard heatshield? So I can't imagine it would even have an effect...
Threads: 55
17
Car Model/Spec: 406 V6
(11-10-2012, 05:05 PM)Prism7guy Wrote: then i can buy some adjustable topmounts to sort out the camber at the front.
What, you think you're going to have some money left over after the beam?
Threads: 1
(12-10-2012, 09:15 AM)sean-306 Wrote: Do you have any dimensions mate? Gonna have a go at making something similiar out of a sheet of ali... Need to re route my battery for my scremer pipe, was gonna put it in the boot, but thats a much better idea!
I don't have a drawing of the undertray, i seem to remember that a metre squared, or a metre by 900mm was all i needed to make it. When i have it off next i'll draw it up with some dimensions for you and put them on here. To make mine i sat the rear end on some axle stands then held the sheet how i wanted it, then drew the profile of it with a marker pen, then used a stanley knife to cut it to shape.
Which mount do you mean?
(12-10-2012, 12:31 PM)Dum-Dum Wrote: That undertray is pretty well thought out, how is the bit near the exhaust coping with the heat?
It hasnt melted yet, so can't be doing too badly.
(12-10-2012, 04:07 PM)Rippthrough Wrote: (11-10-2012, 05:05 PM)Prism7guy Wrote: then i can buy some adjustable topmounts to sort out the camber at the front.
No, no i don't.
Threads: 1
Just had it on a rolling road. Quite pleased with the outcome.
Threads: 178
28
(12-10-2012, 07:04 PM)Prism7guy Wrote: (12-10-2012, 09:15 AM)sean-306 Wrote: Do you have any dimensions mate? Gonna have a go at making something similiar out of a sheet of ali... Need to re route my battery for my scremer pipe, was gonna put it in the boot, but thats a much better idea!
the battery mount mate
Threads: 1
Ahh, no i don't have any dimensions to hand for that either, i'll measure it up for you next time the undertray is off, though internally where the battery sits it will only be a mil or two larger than the dimensions stated for the battery which is a Powervamp 25. I bought the mount off a guy on the gti6 owners club, but i think he got it from powervamp originally.
14-10-2012, 05:48 AM
(This post was last modified: 14-10-2012, 05:50 AM by Poodle.)
Reading this has helped develop some of my own ideas a bit further, think i'm going to spend the day in the garage, hmmm...
Threads: 3
7
Was a really good RR result that, was good to put another face to a name too....
Threads: 1
Recently fitted new rose joints to the droplinks, and fitted new boots lined with grease to protect them. Also fitted new anti roll bar bushes at the same time.
Took it to Oulton park yesterday, wore out around 3mm of the pads by dinner time, the results:
Replaced them within 30 mins and was back out for the afternoon.
Got a knocking noise which can be heard in the videos, hopefully that will be sorted over the winter.
Session 1
https://www.youtube.com/watch?v=2gGrJ4vV...ature=plcp
Session 2
https://www.youtube.com/watch?v=LKGd9WIQ...ature=plcp
Session 3
https://www.youtube.com/watch?v=yXQZ9kX5...ature=plcp
I've taken the car off the road for winter now, i took a few pictures of the battery mounting cage with dimensions, so a PM is coming your way Sean.
Threads: 55
17
Numpty!
Threads: 124
26
Car Model/Spec: Megane DCiR
Love this !! Undertray on rear is cracking idea too
Threads: 1
(03-11-2012, 06:36 PM)Rippthrough Wrote:
Numpty!
 I was suprised how well metal on metal stopped the car.
Threads: 1
02-08-2013, 07:19 PM
(This post was last modified: 02-08-2013, 07:19 PM by Prism7guy.)
It's been a while since i updated this thread, quite a bit has changed!
Since the old brake pads had worn out i decided to put my AP racing 4 pots to use rather than spend money on more pads for the standard calipers. Took loads of measurements and started drawing things up, i wanted to fit 310mm or 315mm discs under my 15" TD Pro race 1.2's if it was possible. In the end i went with 310's and had to get some custom made pads to suit the setup, the biggest issue was spacing the rotor back as far as i could towards the ball joint, meaning i wouldnt have to space the wheel out so much, but ensuring i wouldnt have any balljoint to rotor contact.
I'll let the pictures do the talking.
![[Image: 9BC2E0EF-1A34-47E9-866E-1143F6161BB9-147...3f5854.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/9BC2E0EF-1A34-47E9-866E-1143F6161BB9-1473-00000385231EB6A9_zpsfc3f5854.jpg)
(Testing how far i could space the rotor back)
![[Image: 1054855C-13A2-4607-A19B-DDF360217ACF-147...877b4b.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/1054855C-13A2-4607-A19B-DDF360217ACF-1473-00000385DA7B4D33_zps31877b4b.jpg)
(Testing the caliper position etc on a spare hub)
![[Image: F3D4C2F9-8A8F-48E4-98AE-A3A9EEDEBB1C-147...750f88.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/F3D4C2F9-8A8F-48E4-98AE-A3A9EEDEBB1C-1473-000003862621C0DF_zpse2750f88.jpg)
(Mock brackets checking clearance in the wheel, also seeing how far the wheel would have to be spaced out)
![[Image: 31CAAB3A-B2BC-4439-9A49-FB29ECBE4D69-147...7a03c6.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/31CAAB3A-B2BC-4439-9A49-FB29ECBE4D69-1473-00000386528977A2_zps387a03c6.jpg)
(Started turning the bells)
![[Image: 965C5103-6E8F-4B1B-A8DC-2505DC076333-147...ae4246.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/965C5103-6E8F-4B1B-A8DC-2505DC076333-1473-00000386695C35E8_zps17ae4246.jpg)
(Second end of the bell being turned)
![[Image: 99B9C347-A652-44FA-840A-2FB96F8EEFCE-583...e4d37a.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/99B9C347-A652-44FA-840A-2FB96F8EEFCE-5835-00000EA55C693B1B_zps54e4d37a.jpg)
(Bell drilled and countersunk)
![[Image: 99A9A0E0-A287-4D1F-B312-63D366776F48-583...7b7b1e.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/99A9A0E0-A287-4D1F-B312-63D366776F48-5835-00000EA55202B834_zpsee7b7b1e.jpg)
(Caliper bracket milled)
![[Image: EA57C22A-361E-4F48-9640-0DACA452E962-101...e2026f.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/EA57C22A-361E-4F48-9640-0DACA452E962-10116-0000174AF794441E_zps55e2026f.jpg)
(Few ally bits hard anodised black)
![[Image: 8C8D21D4-F94F-4597-B60D-DFEB5062FB27-101...aff03e.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/8C8D21D4-F94F-4597-B60D-DFEB5062FB27-10116-0000174B16C6F670_zps98aff03e.jpg)
(Calipers after powder coating)
![[Image: 6EC3EC23-1B9D-4050-9135-264242AD2874-101...e5e5b6.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/6EC3EC23-1B9D-4050-9135-264242AD2874-10116-0000174B213273D5_zpsb9e5e5b6.jpg)
(All new pistons, seal kit, disc to bell mounting kit and bleed nipples)
![[Image: 499CA26E-6109-465B-9603-CD9316F8528D-121...353d22.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/499CA26E-6109-465B-9603-CD9316F8528D-12108-00001B566FB513F7_zps7f353d22.jpg)
(On the car)
![[Image: 333AA0DF-5335-41CD-9519-D6923057C3DF-121...6edff5.jpg]](http://i33.photobucket.com/albums/d71/prism7guy/Track%20car%20pictures/333AA0DF-5335-41CD-9519-D6923057C3DF-12108-00001C06933CDB2F_zpsdb6edff5.jpg)
(Wheel on)
I also decided it was about time i sorted out the rear beam. I had some 21mm torsion bars and a 30mm anti roll bar stashed under my bed for months
Basically fitted two new trailing arm shafts, all new bearings and seals etc.
Since i go to the nurburgring every year i needed to get some new seats without the ears which wrap around my head to meet the new rules/regulations, also had to add padding to the roll cage wherever i could touch it. So this is the result of that:
I think the final thing i did before i went was to have the oil cooler lines crimped properly rather than use jubilee clips as i noticed one had started weeping a bit and didnt fancy the idea of losing all the oil randomly.
I also bought and fitted some new topmounts for the front, giving around an extra 2 degrees of negative camber, after fitting them i re-tracked the car and set it to parallel toe just like before.
I eventually got to the 'ring, nice weather all weekend for once but it's way too hot in a car with lexan windows and no real way of cooling it down.
Got nine successful laps in over the weekend, but the track was almost constantly closed on the saturday so only managed to get 4 laps in that day. On the 4th lap i carried too much speed into a corner with a BMW ahead, they braked and started to get close to the kerb leaving not a lot of room for me so i had to get two wheels on the grass and go over the high kerb, that whacked the exhaust and started a crack around where the downpipe enters the centre silencer, didnt take long for it to completely snap.
But i carried on with it like this through sunday, turned everyones heads in the 'ring carparks with the state of how it sounded, not for it being a nice sound either.
I'm sure it was down on power/torque like this as it would bog down in 6th in places, but i managed to get a new pb of 8:35BTG so all in all it was a successful trip.
https://www.youtube.com/watch?v=lCmU-aVTVKU
Since i got home i got the exhaust off, took out the perforated tube that ran through the centre box and welded the tube back onto the box. It doesnt seem much louder, i think it may be down on power a little but it'll do until i get a new exhaust sorted, it turns out this one is only 2" in places so i don't know if going for 2.25" would release a bit more or not, i know it seems to feel a bit restricted from 6,500rpm onwards. Anyway, i'm hoping to be boosted in the next couple of years so i'll probably go for a 2.5" system making sure it will keep the car quiet enough for trackdays.
I'll end the update with a few pic's from the 'ring.
Threads: 169
91
I have been following your build on the '6 forum. Whilst I am not a member there, it has proved a very interesting read.
This is an amazing build. The attention to detail, and bottomless pit of shiney bits is incredible. Keep us updated!
Threads: 24
Car Model/Spec: 306
Threads: 48
Looks amazing, cant believe i have not seen this before. Great attention to detail.
8.35 is awesome, standard power?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
02-08-2013, 09:11 PM
(This post was last modified: 02-08-2013, 09:12 PM by Jenkosowls.)
Think the dunno day it had made 187bhp or 178bho something like that some doubt the result but at end of the day there was cars there that made bang on book spec
Btw lookin into another dyno day soon!
www.prestige-auto-care.co.uk
this is epic. makes my build feel pathetic
Threads: 1
Thanks lads, as far as i know the engine is standard (picked it up from southampton for £300), it got 182bhp 158lb ft at a dyno day last year. I suspect it may have cams as it doesnt run smoothly around 2000rpm and it can sometimes sound cammed at idle, the ecu was from the previous engine so hasn't been mapped.
I'll probably be up for another dyno day to see if it gets similar to last time, i think a wheel bearing is on the way out now though.
Threads: 289
92
Car Model/Spec: Phase 17 R26
What a great update, you should post more often! Thanks for posting the 'ring video too, great watch
Threads: 448
51
Love this build. Got to be one of the only blazes I like!
Threads: 119
15
Don't remember seeing this at fcs this year didn't fancy it?
Threads: 141
35
I really like this, really nicely thought out
Threads: 541
124
Threads: 1
(02-08-2013, 10:56 PM)Jenkosowls Wrote: Don't remember seeing this at fcs this year didn't fancy it?
I've been trying to save money recently and Castle Combe seemed a bit far to justify taking the car so soon after it's trip to the 'ring. I'll probably take it to FCS next year if i've not bought a house and living like a hermit by then.
Threads: 35
Great video of the ring! Every credit for taking corners and jumping at 120mph :O
CONVOI EXCEPTIONNEL
Threads: 102
9
now this a build thread, how far you going to go? ie supercharger
Threads: 1
(03-08-2013, 10:57 PM)procta Wrote: now this a build thread, how far you going to go? ie supercharger
It's on the cards for sure, other financial commitments are getting in the way though and i could do with getting myself on the property ladder at some point.
