30-09-2012, 07:29 AM
If you want a set of runners for that seat hit me up. I have some spare
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Dum-Dums Bianca GTi6
30-09-2012, 04:24 PM
(30-09-2012, 05:09 AM)C2K Wrote: Sparco greyhound?lightweight dog for lightweight car lol (30-09-2012, 07:29 AM)Matt Wrote: If you want a set of runners for that seat hit me up. I have some spareNo thanks cos theyll raise me back up again and i dont want that. Im gonna make a better attempt at it at some point in the future but itll do for now.
30-09-2012, 07:17 PM
So the latest weights
GTi6 Drivers Seat = 20600g DTurbo Drivers Seat = 18600g Drivers seatbelt = 2320g Sparco seat, subframe and harness = 13000g Drivers Seat difference = 9920g GTi6 passenger Seat = 18600g DTurbo Passenger Seat = 16600g Passenger seat difference = 2000g Passenger seatbelt = 2270g Passenger Harness = 1330g Belt difference = 940g Standard backbox = 9800g Aftermarket backbox = 4400g Backbox difference = 5400g 406 Brembo callipers and pads (pair) = 7630g Xantia V6 discs (pair) = 15920g GTi6 Calipers and pads (pair) = 13000g GTi6 Discs (pair) = 9920g Brakes difference = 630g Door Cards std pair = 5720g Door metal parts = 250g Door Cards Carbon Fiber = 2140g Door Cards Difference = 3830g Rear window glases (pair) = 4100g Rear window seals (pair) = 1060g Rear window plastics and bolts = 100g Polycarbonate windows (pair) = 1240g Rear window difference = 4020g AC Compressor = 6720g Front mats = 1230g Fuse box cover = 40g A pillar trims = 410g Roof lining = 1570g Rear interior roof light and clips = 140g Sun Visors = 720g PAS belt cover = 60g Rear roof handles = 190g Passenger airbag = 3000g Airbag ECUs and wiring = 1430g Front carpet = 6060g Lower glove box = 1060g Front door seal trimmings = 300g Gear gaiter = 160g Center console front = 1630g Centre console rear = 730g Centre console plastics and bolts = 250g Tar (so far) = 810g ADDITION Fire extinguisher = 2100g Total for the above = 51.15KG LOST!
30-09-2012, 09:36 PM
Is that 51.15kg from the start?
30-09-2012, 10:29 PM
I think if I had a wank right now it'd weigh about 51.15kg....
30-09-2012, 11:38 PM
No, that's another 51kg, already had ~90 out in the last post like this i think.
01-10-2012, 09:57 AM
(30-09-2012, 09:36 PM)Scott Wrote: Is that 51.15kg from the start? Nope (01-10-2012, 03:56 AM)Poodle Wrote: No, that's another 51kg, already had ~90 out in the last post like this i think. Correct IIRC it was 87kg on the last load i put up so its almost 140kg off in total. (and i forgot to weigh the aircon rad and pipes) I just need time and not insignificant amount of money to make it any lighter. Tempted by a smaller battery to relocate and need to strip down looms then its lightened engine bits, fiberglass pannels and i could probably shed another 10kg with a pair of proper fixed buckets. Might stick her on the weighbridge at some point this week and see what it says.
09-10-2012, 05:42 PM
So washed the car today, decided after playing with some black tape (that wouldnt stick very well) that im gonna paint a 1" strip pf the rear window edges to make them look more OEM.
Also over the last few days smoothed and painted my bonnet. I cut the backing to the badge off then epoxyed in some bits of ally strip and box section so that I didnt need too much fiberglass. I then filled with fiberglass till just below the level of the bodywork and packed it in front and back so I only need a thin skim of filler Then fillered, sanded, fillered, sanded, fillered, sanded, fillered, sanded and wet and dryed it to shape. Then about 8 coats of primer and it was wet and dryed back and re masked then about 6 or 7 layers of top coat and thats how we stand. The paint match is terrible, the paint i have is ph2 bianca and was a great match on my door handles but its miles out on the bonnet that is lighter and whiter being a ph3 item. This picture dosent show how bad it is. Anyway heres how she stands, need to finish repairing my fiberglass grille and paint it. Oh and note the GTi badges have fallen off the sides cos i didnt like them without the 6s Just need to wait for it to harden and its a week till im next off so then i'll go over it with the rubbing compound and try my best to blend it in. (dosent look too bad from a distance though)
09-10-2012, 05:47 PM
Surely filling holes goes against your ethos?! Now you're going to have to remove a wheel
Looks good, will look so much better with black around the windows.
09-10-2012, 06:02 PM
Gunna be nose heavy....
Although you can actually see te difference in paint from the whole bonnet compared to the wing. But only of you look hard lol ![]() TEAM CONROD SHITTING RALLYE!
09-10-2012, 06:23 PM
White seems to be a hard colour to match, 205's use different shades of white under the same name which is a pain.
Will you be joining me in the 50 shades of white team now?
Stage 2 XUD Sedan
09-10-2012, 07:50 PM
(09-10-2012, 05:47 PM)Curt Wrote: Surely filling holes goes against your ethos?! Now you're going to have to remove a wheelYeah it is a little but buying a new badge when im eventually gonna have a smoothed lightweight fiberglass bonnet when ive got the money to go with the fiberglass grille thats in my garage. So its a temporary measure. Cheers for the compliment though mate. (09-10-2012, 06:02 PM)Matt Wrote: Gunna be nose heavy....Yeah the bonnet is a terrible match cos its ph3 bianca not ph2. and yes nose heavy mate, esp when i get the saxo pump on. (09-10-2012, 06:23 PM)strictly_derv Wrote: White seems to be a hard colour to match, 205's use different shades of white under the same name which is a pain.Yeah theres at least 4 shades of bianca on mine if not more.
09-10-2012, 10:36 PM
Just had a ninja late night delivery of oily bits to play with from The Thorne - Cheers Callum
Also shouldn't of gone to Scotts earlier. Spent more money that I dont have on shinys off the car hes breaking mainly to make mine look prettier. My Little Slag Bianca is gonna be looking and sounding incredible for the Christmas meet.
09-10-2012, 10:40 PM
What've you bought then...?
09-10-2012, 10:43 PM
Curt on a completely unrelated note I've just noticed that the right hand side image of your car in your sig has been flipped (I'm guessing so the background seems to match more) but now that means the exhaust is on the wrong side!
09-10-2012, 10:46 PM
Yes you are correct, it's so it works better... You're not supposed to point that out though
![]() I should have done it with the picture of the front, but I thought of it after and couldn't be bothered ![]()
Scott you anus....
24-10-2012, 02:05 PM
24-10-2012, 02:28 PM
Love it
24-10-2012, 03:19 PM
pikey as ever
![]() what you doing with the plemun? can i have it? Member of the 99% warning or you're nothing club
24-10-2012, 03:24 PM
Bodgetacula!
24-10-2012, 03:32 PM
you using stock ecu? with all the original sensors like yani on the 6 forum?
If you want more info Maz who was asking about 106 rallye manifold for his 1.6 306 did the yani conversion on his old gti, it sounded epic but it didnt make much difference. ![]()
24-10-2012, 06:01 PM
(24-10-2012, 03:24 PM)Niall Wrote: Bodgetacula! (24-10-2012, 03:32 PM)Fozzy Wrote: you using stock ecu? with all the original sensors like yani on the 6 forum? These^^ It will sound porno though!
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING!
24-10-2012, 09:50 PM
That was a smart work-around the guy on the 6 forum did with his Xsara VTS (?) I think it was.
Going to sound incredible Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
24-10-2012, 09:56 PM
TBH i cant see many power gains without getting it mapped. Once again, this will fail and i have no faith in your abilities to make this work.
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft |
Bianca White Phase 2 Gti6 Track & Fast Road Car | Chr1sch | 62 | 19,494 |
22-02-2016, 01:54 PM Last Post: Chr1sch |
Dum-Dums VNT 2.1TD OEM+ Bianca Estate. (loads of pics and video now added) | Dum-Dum | 737 | 341,986 |
10-09-2014, 04:43 PM Last Post: Dum-Dum |
The 2.1TD Bianca Sedan - Dum-Dums Project Cheap | Dum-Dum | 330 | 160,460 |
21-01-2013, 11:40 AM Last Post: Dum-Dum |
