Sean's Diablo HDi Stage 2 168bhp & 290lbsft
£22 from car parts 4 less.
Have fun fitting a cable they're a pain in the arse! Smile.
Plans sound good. Think once mines running again I'm going stage 2 over winter Smile.
Finally sent myclutch of to get replated, then found out that im being sent away to Jordan for 3 months, so car aint gonna be done till ages away!! Gutted!
bad luck! i presume there will be many monies to spend on it once you return though?
Oh deffiantly! but im not sure what i need! Wheel refurb maybe...
But still need to get all the shiny parts fitted and mapped yet! Its just a bit of a PITA but its part of the job really!
Just had the invoice back for my clutch...
Helix Autosport Wrote:Rebuilt cover inc pressure plate - 103.00
Re pad 4 Paddle - 49.59
Total inc vat - 183.11
Not too bad considering i only payed 40quid for the clutch.
Deposit has been payed on '6 brakes and master cylinder, phase 1 gti seats and a phase 3 splitter and i might be getting halos...
Opinions on new colour for alloys?
I'd say a nice bright silver.
Oh and feel free to donate your clutch to meeee!
S2 HDi >click<
154bhp
280lbs/ft
You say you got/getting some gti seats. You do know that 3 door seats dont fit a 5 door? They can be made to fit but theres alot of work involved.
yeah, i no the rears wont fit, had 3 door nova gsi seats in my 5 doornova. Just need to put the rear mounts across abit.
Get your own clutch! Tongue
Black angels or black masks?
You can buy my black angels if you want sean?
Productive evening at the motorclub....
'6 splitter fitted, '6 brakes fitted, lower anti roll bar fitted & decat...
slight problem with the decat though... its knocking on the subframe, short of grinding the sub frame down a bit and the same with the decat, i cant think what else to do!
Ive even raised the middle exhaust clamp to try and lift it a bit more...
Thinking about trying to find a pipe bender and just give it a little knick just so it misses the subframe...
(15-10-2012, 09:22 PM)sean-306 Wrote: Productive evening at the motorclub....
Get an angle grinder cut a slit in the pipe, jack up by the slit to bend the pipe up slightly and bring the two edges closer together, then weld them together. Simples.
so cut the topside of the cat and squash the pipe so the slit is covered, this will bend the cat upwards and then just weld it up.
sounds too simple!
Rung up an exhaust place in basingstoke who are going to have a look and bend the exhaust so it misses, it only just hits atm, but its enough to make a shit noise in the cabin!
Will be sorted today or tomorrow, and ill get some pics of my new stuff!
Front end
New brakes
What do the new brakes feel like compered to the standard ones?
What are your engine mounts like? My exhaust used to catch the subframe, had too much movement in the engine
[Image: SDC10442-1.jpg]
looks smart dude Smile always had a soft spot for diablos i miss mine really bad Sad
(18-10-2012, 07:09 PM)Chris_90 Wrote: What do the new brakes feel like compered to the standard ones?
Not had a chance to "drive" themyet cos of the rattle...
(18-10-2012, 07:13 PM)Jonny b Wrote: What are your engine mounts like? My exhaust used to catch the subframe, had too much movement in the engine
Mounts are fine... ive got an inch clearance between the bottom of the exhaust and the subframe...
the knocking onlycomes when the clutch is engaged....
Um, sorry to piss on your fire, but that means your mounts probably aren't fine lol.
Would engine mounts be a possible cause of a grinding / knocking noise when my car is in reverse too? As there's no vibration through the 'box, so there's probably not an issue with the gearbox itself.
[Image: Sig500x130.png]
As poodle said bud mounts are probably shot, check the top mount that's usually first to go and causes most movement
Mounts easy to change... imagine they're a lady garden as most things are on french cars!
Mounts are really easy to change. Apart from bottom mount, that's a pig!
So, a few updates, but no pictures...
Have bought some BakerBM Engine mounts and solid rear beam mounts, hopefully that sorts the exhaust banging. Also, going to buy new exhaust bushes.
Am going up to see scott when i get back topick upthe mounts and also some leather reclining buckets. Have got black angel eyes coming too...
Will be getting all this sorted in the run up to xmas, so pictures soon. Have pm'd krisb about getting my turbo and clutch fitted in january. The turbo is Dums old ko3/ko3s hybrid.
Dum, did you and kris have any problems installing it, do i need anything extra to go with it, still got oil feeds and the screamer pipe. Also dum, did you have to vent your battery as ive heard its required if your re-routing it to boot... Did the thick gauge wire run under the car or through the car?
Have read through dums old hdi project, and its given me the idea of a piper cam and lightened fly... Pros and cons?
Piper only list the 206 hdi for cams, is it the same engine?
Im going to get hold of lynx to see if they will make a lightened bottom pulley (group buy intrest?)
Wish i earnt more money!!!
A lot of money going to this!!!
S2 HDi >click<
154bhp
280lbs/ft
Shhhh! Dont remind me!!
Will be worth it the end i think...
you hope Tongue
good project though mate. is moving fairly quickly
Am also currently the highest bidder on an omp steering wheel.
Didnt want to go down the becauseracecar look but i cant help myself!
Was looking at lynx front wishbone bushes earlier too...
Want/need some new top mounts aswell... aswell as some better coilovers... Cant wait to get my op bonus for afgan!
vibra technic P bush are well worth the money IMO if your looking at up rating bushes
yeah i am, i did the drivers side pbush with a standard new one, and it was a pita so i only did the one :/ That was about 5months ago...
My bad!
  SRowell's Stage 1 Diablo HDi Estate Eeyore 390 212,419 14-06-2015, 06:20 PM
Exclamation PH1 genesis STDT sedan! Stage 2 soon be stage 3 GT20 strictly_perv 127 48,281 16-06-2014, 05:06 PM
Last Post: MissTap_GTI6
  Sean's (& Ed's & Scott's) Astor GTi6 Ed Doe 807 440,461 27-08-2013, 09:22 AM
Last Post: Poodle
