Threads: 170
hi guys the gf has been out in the car today and now the window wont close. there is a break in the loom witch i have tapped up. the light on the switch comes on but it wont move and its starting to rain. can anyone advice me on how to close it. dont fancy the window been open all night. cheers guys
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 87
31
Bloody women.
Try using a knife or a gun, should fix the root of the problem quickly and easily.
HTH.
Threads: 18
Door card off and run a +ve and -ve directly to the motor, then leave the motor unplugged till ya get it sorted!
Threads: 202
58
failing that, if the motor's buggered, take the winder off the motor (just 3 screws IIRC) and turn it manually with long nose pliers.
Threads: 170
(17-09-2012, 05:43 PM)Harky Wrote: Door card off and run a +ve and -ve directly to the motor, then leave the motor unplugged till ya get it sorted!
you mean run a wire from the battery to the motor and it will go up?. what if the motor has gone is there a chance it can shut?. cheers
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 18
Aye, just pull door card off, and if you have a multimeter you'll probably find a 12v somewhere at the switches, run a wire from there direct to the motor, or if you have a spare battery you can just run it from there. If the motors buggered then do as Jonny suggests.
When you try to move the window can you hear anything happening?
Hopefully you can't in which case it will just be the motor, or more likely just the door loom wiring. Bare in mind that the door loom on the drivers side also affects the passenger side, ie a brake drivers side can stop passenger side from working!
Threads: 170
done it. took the motor out then the end bit and got a torx screw driver and wound it up . take take a while.
the passenger side is totally shot and has been for a while. the wires are black and the connector was shot. passengere window did work but was abit crap. going to find another motor and loom. cheers for the help guys
Ph3 perv cab heaven
Black ph1 XUD died
