passenger window doesnt run all the way back up
My passenger window does not run all the way back to the top. On the way down its perfect but it struggles like to hell to come all the way back to the top. it stops about an inch shy to the top of the door. I am thinking the loom? and where abouts is the loom?
Thanks in advance
Its the motor/wire mechanism that is worn likely.
that or its dislodged off its runners
Need to remove door card and have a good gander Smile
(if you find lots of metal filings around the motor/mechanism, sure sign of failure!)
cheers mate. The door card is off now. i have already replaced the little plastic clip that goes into the seal. So what are the tell tail signs that the mechanism is to blame?
Got a simalar problem my window goes up but wont go down think.it may be becasue i had a dturbo door and a gti 6 dr with diff looms
  Heater control doesnt seem to be working davey 6 5,565 13-05-2017, 11:48 AM
Last Post: Chris HDI
  Passenger Window wont go up! mspdan 2 2,677 17-01-2015, 11:33 PM
Last Post: shazilla
  Wiring loom needed/passenger window stuck open... Mattinthehat 4 4,042 18-09-2014, 03:30 PM
Last Post: Mattinthehat
