Clarke OBDII Fault Code Reader
#61
That's odd Cully, because a lot of the ones i work with won't let me connect if i try in the first few seconds, i usually have to leave the ignition on and restart the global scan after a minute or so.
(11-10-2012, 04:07 AM)Poodle Wrote: That's odd Cully, because a lot of the ones i work with won't let me connect if i try in the first few seconds, i usually have to leave the ignition on and restart the global scan after a minute or so.
maybe its different between different ecu codes
(in talking about the elm here not the PP)
#63
Aaaaaah thatll be the difference.
  Peugeot Fault code Welshy_Pete 8 5,567 09-08-2017, 08:09 AM
  Glow plug fault code? JTaylor2005 2 2,742 22-05-2016, 12:22 PM
Last Post: JTaylor2005
  Ecu reader with map on it to delete lights MIKE-FORD 0 1,892 05-04-2014, 10:20 PM
Last Post: MIKE-FORD
