Cully's Bianca 6 R150 YVM
(28-10-2015, 05:55 PM)Dum-Dum Wrote: Good to hear it goes well, a decent gain in power by the sounds of it then?
ive fitted the lightened pulley and flywheel to this engine so effectively a power gain yes
other than that it was built to standard spec with ACL main and bigend bearings
one thing i am impressed with is the Castrol edge oill, on how it maintains the oil pressure even when the temp climbs,
at all times i am getting 6.5bar above 4krpm
i need to put that to test on some track work Wink
GTI6 Info
car is still going well other than a fuel leak from the rubber hose on the fuel rail to which i replaced the rubber for now!
ive started the process of replacing the rubber joints on the fuel line, im going to be fitting braided fuel lines,
the main reason in doing this is to remove the 10 joints in the engine bay on the fuel line flow and return.
I am going to be replacing them with AN6 aeroquip type fittings and stainless braid ptfe 8mm fuel lines
to start off ive bought some weld on AN6 fittings
[Image: 20151218_191554.jpg]
to fit these i have cut the rail end off and drilled the fitting to the same size as the rail tube
I then silver soldered the fitting to the rail
[Image: 20151219_101541.jpg]
2nd fitting soldered
[Image: 20151219_103316.jpg]
I had to clean up the rail and what better way of stripping the rust paint and crud
Electrolisis....
12 hours later and a quick wire brush
[Image: 20151221_093140.jpg]
[Image: 20151221_093204.jpg]
now for some paint
1 coat of galvanise primer
[Image: 20151221_104834.jpg]
1 coat of primer
few coats of black
more to come..........
GTI6 Info
ffs.... make me an electrolysis setup. Everything always looks so good afterwards!
It's just a plastic box a battery charger and some scrap metal for the anodes, and some washing soda and water.
exactly that im using a tall bucket soda crystals and a battery charger
+ terminal clipped to some mild steel plate
- terminal clipped to the piece needing cleaning
dont use or try to clean Aluminium parts Wink
GTI6 Info
coat of primer....
[Image: 20151221_122750.jpg]
GTI6 Info
fuel line parts ordered...
2 X AN6 weld on steel fitting
4 X AN6 BLACK 45 Degree Swivel TEFLON PTFE Fuel Oil Braided Hose Fitting
1 X mtr AN6 5/16" 8MM Stainless Steel Braided TEFLON PTFE Fuel Hose
2 X AN6 to 5/16" 7MM - 8MM BLACK PUSH ON BARB Straight Hose Fitting Adapter
1 X AN6 15mm RED HOSE END FINISHER
1 X AN6 15mm BLACK HOSE END FINISHER
GTI6 Info
with the top coat of black
[Image: 20151221_144331.jpg]
GTI6 Info
where are the two hose fiishers going?
they will be used over the barb fittings into the std plastic lines
two colours for flow/return identification
GTI6 Info
Nice work cully!
Hmmm........
the 2 X AN6 to 5/16" 7MM - 8MM BLACK PUSH ON BARB Straight Hose Fitting Adapters
are the wrong size for the plastic hardlines
have to try a different size Sad
Bum!
GTI6 Info
I think you'll be converting to 8mm metal lines and using a pair of an-6 to 8mm compression fittings...
i dont really want to go down that route but its an option if this route fails,
i want to use the std plastic hardlines from back to front and pick up on the inerwing
GTI6 Info
i seem to be having an issue in finding fittings that fit the peugeot Plastic fuel hard line, it turns out the peugeot pipe is measured 8mm outside diameter when all pipe fittings are measured by there internal bore diameter
there are no AN6 barb fittings available for the peugeot 6.5mm internal bore pipe!
the 2 X AN6 7MM - 8MM PUSH ON BARB where to big to go into the pipe
i bought some AN6 6mm barbs these were to small
and i cant find anywhere a barb fitting between these two sizes Sad
so...........
i have taken the AN6 7-8mm fittings and turned them down in a lath to make them 6-7mm
GTI6 Info
Sounds like an utter ballache.
that's why I have 8mm o.d metal pipe under my ZX with a pair of compression fittings on the bulkhead.
Is it worth the hassle? Surely new standard pipes would last another 10 years or so?
Can you warm up the piping to stretch it over the AN barbed fittings?
(07-01-2016, 11:31 AM)Piggy Wrote: Can you warm up the piping to stretch it over the AN barbed fittings?
Definitely possible as I've done it before although advisable to only do it in boiling water rather than with fire.
lmao
62k Diablo Phase 1 Gti-6:
Project Thread
lmao
im sure your not being serious Chris as hot water is not hot enough to get the pipe soft enough to strech it over the barb
ive binned the barbed idea as i dont like the idea on the fuel line!
I'am looking at inserts and compression olive fittings for the plastic hardline now Wink
GTI6 Info
Heat gun would do the job, no?
yes im sure but would you trust a barb fitting you fecked with at 50-60-70psi with petrol running though the joint near a hot exhaust manifold ?
GTI6 Info
(09-08-2015, 07:29 PM)cully Wrote: suns out trip to the tip to dump some rubbish and it would be roude not to buy a new tool!
what a cracking bit of kit no more bent lifting points or using crap chains
[Image: 20150809_184654.jpg]
anyway so today was a big day for Bianca she lost her heart!
[Image: 20150809_155321.jpg]
[Image: 20150809_172127.jpg]
[Image: 20150809_175130.jpg]
[Image: 20150809_180013.jpg]
not atall bad on my own i dont think
the new load leaveler worked real well in canting the engine around the gearbox mount before lifting it clear
once the bay was clear i could see some bits on the legs that needed sorting but after a poke and a scrape its all surface and treatable very easy with a sanding disc and some paint
which is Good news
[Image: 20150809_184441.jpg]
[Image: 20150809_184450.jpg]
and a small section under the ABS pump
[Image: 20150809_184521.jpg]
Gear box mount is in excellent condition too
[Image: 20150809_184502.jpg]
while i was in there i cut out the last of the Aircon pipework behind the engine now im just left with the two matrix stubs at the bulkhead which i can live with Smile
[Image: 20150809_184413.jpg]
ive got some more metal to clean in the electrolisis tank before i pait them so have started that off too
[Image: 20150809_184419.jpg]
[Image: 20150809_194617.jpg]
so in all today has been a very productive day
there are a few things i still need to get  but we will start on the paint tomorrow Smile
how does that tank work? (what's it hooked up to?)
Hate Housework!
(09-01-2016, 11:03 AM)cully Wrote:
(07-01-2016, 12:17 PM)Dum-Dum Wrote: Definitely possible as I've done it before although advisable to only do it in boiling water rather than with fire.
I managed to do it and get the hard pipe stretched over a barb.
There was alot of brute force involved but everyone loves stuffing a fat barb up a tight pipe.
(09-01-2016, 11:35 AM)Magenta Sunset Wrote: how does that tank work? (what's it hooked up to?)
look here for more info Wink
http://306oc.co.uk/forum/showthread.php?...#pid406099
GTI6 Info
Question
Good news regarding the rust situation as all that is easy to take car of.
Sure Adam had me rip the aircon out as it was f*cked many moon ago.
What engine is going back in?
(10-01-2016, 09:00 AM)roland rat Wrote: Good news regarding the rust situation as all that is easy to take car of.
scroll back about two pages for the engine
i refreshed a std engine rings bearings seals the works and have fitted that with lightened flywheel and pulley Smile
the air con was still in this car when i bought it now there is none left in the engine bay as ive removed all the pipework and compressor
GTI6 Info
brilliant. i'm impressed ThumbsUp
Hate Housework!
  cully's XU10J4RS cully 11 10,108 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 96,560 16-04-2016, 04:14 PM
Last Post: cully
