Cully's Bianca 6 R150 YVM
what an epic time  on track at FCS the car went brilliant
tyres held out well i was expecting to kill them but i believe they will go again as the still have pattern left Smile
[attachment=23634]
as for the Brakes i knew they were low and i havent changed these since ive bought the car, so to be fair they have done well.
but after the 2hrs session they were bad but working.
but when dum dum came over waving his track pass I had to go out again!
 once with chris who was promptly feeling Ill after about 5 laps,
 once more with james who i think enjoyed himself so much made him regret selling his Rallye and buying a Subaru
after track sesions brakes were heavy vibration under light braking so they were dead
so today has been a day of brake rebuild
off with the old
[attachment=23638]
on with the new!!
out for a road test and they feal like new Tongue
[attachment=23635]
[attachment=23636]
[attachment=23637]
GTI6 Info
Those old pads and discs really are destroyed.
Oh and to add
anyone wishing to do a 2 hour on track
i spent
£100 on Vpower and i needed a £20 splash and dash to get home as I hit the Fuel light about 20 miles from home
Total miles for the day including track
170 road miles 140 track miles around 75ish laps
GTI6 Info
(07-06-2015, 03:03 PM)cully Wrote: Oh and to add
i spent
Impressive
£100 at 1.25ppl is 80l and the best part of 18gal
170 motorway miles at 35mpg is the best part of 5gal
That means 13gal on track, not quite single figure MPG but close 10.9mpg lol
My gauge dropped from half a tank to a quarter in the few laps I did.
[attachment=23695]
GTI6 Info
Looking good mate, the passenger at least LOL
The 6 looked brilliant on track Paul, shifted around corners really nicely Smile
Cheers Paul had great few laps hacking through traffic with you Smile
So when you getting that diff then.... It's even tempting me
[Image: Cn91r40h.jpg]
well id very much like that diff!!
but for the two or three times a year i use the car on track,, i cant justify it.
the car was bought originally as a weekend toy which it suits its job very well as a nearly std car.
it brings smile to my face even though it not the fastest on track
ive been looking at the autumn action day tickets which are broken into 15 min track times im not sure if im keen
i may look at a track day instead Wink
[attachment=23730]
GTI6 Info
Yeah after last time I'm slightly going out action days and for what I spend I could do a evening open pit somewhere
Grins**
look what ive just picked up from the sand blasters have just dropped them off to be powder coated
[Image: 20150629_162614.jpg]
GTI6 Info
Today is a sad day!!
but its a beginning of a new chapter for the car that should keep it on the road for a year or two more
I hope!
anyway FCS was the last straw for the engine
probably a combination of a few bad choices of mine and add a high ish mileage engine didn't help
poor oil choice for track use
not knowing to say no to freebees
ended in the engine expiring with a heavy rattle  after i got home
so tonight i have cleared my drive to make Bianca a nice home for a while so good things can happen
so it started tonight with a visit to the DVLA website
GTI6 Info
Jesus sounds like a tractor haha
Free hangover cures!
Time to go to work! Big Grin
Sounds rough mate, time for some shineyness I think
Thanks for the card btw Smile
What happened there then? Super-duper snake oil additive?
Good times which resulted in a bad time for the head which will now result in a better time for the car in spring ThumbsUp
Love the wheels...you wheel whore
I doubt there's anything at all wrong with that head.
(01-08-2015, 08:09 AM)welshpug Wrote: I doubt there's anything at all wrong with that head.
im hoping the head is ok
but
im also hoping the bottom end is ok as i already have an engine that needs a bottom end Sad
GTI6 Info
It'll all be fine, just chuck some of the 20w50 Wilko oil in it, should quieten it down... Wink
Sad times but onwards and upwards. That new engine is going to look mint in that bay when its all done. Also, my money is on big ends when you finally strip the old one down to have a look
That is knocking it's tits off.
but
Still got most of one sat in my shed :innocent:
dont know if anyone is interested but ive done compression test on the engine
i think it shows that its the bottom end or tell me different?
cylinder 1 14.5bar (gearbox end)
cylinder 2 14.5 bar
cylinder 3 12 bar
cylinder 4 14 bar
warm cranked with WOT no plugs/double relay unplugged
GTI6 Info
Whats standard comp press?
no idea but the gauge was well into the green on all 4 readings
GTI6 Info
Just says it's got lower compression on one cylinder, but well within specs, I bet if you gave cyl#3 a squirt of WD40 it'd raise a little to the same as the other cylinders, I wouldn't say gasket or ring has failed or anything like that...
After re-listening it sounds like a possible spun bearing or similar.
what ever has happened to the engine it wont be a while till i strip it , but I will, as I may be able to make a good engine out of the many I have here whistle
GTI6 Info
suns out trip to the tip to dump some rubbish and it would be roude not to buy a new tool!
what a cracking bit of kit no more bent lifting points or using crap chains
[Image: 20150809_184654.jpg]
anyway so today was a big day for Bianca she lost her heart!
[Image: 20150809_155321.jpg]
[Image: 20150809_172127.jpg]
[Image: 20150809_175130.jpg]
[Image: 20150809_180013.jpg]
not atall bad on my own i dont think
the new load leaveler worked real well in canting the engine around the gearbox mount before lifting it clear
once the bay was clear i could see some bits on the legs that needed sorting but after a poke and a scrape its all surface and treatable very easy with a sanding disc and some paint
which is Good news
[Image: 20150809_184441.jpg]
[Image: 20150809_184450.jpg]
and a small section under the ABS pump
[Image: 20150809_184521.jpg]
Gear box mount is in excellent condition too
[Image: 20150809_184502.jpg]
while i was in there i cut out the last of the Aircon pipework behind the engine now im just left with the two matrix stubs at the bulkhead which i can live with Smile
[Image: 20150809_184413.jpg]
ive got some more metal to clean in the electrolisis tank before i pait them so have started that off too
[Image: 20150809_184419.jpg]
[Image: 20150809_194617.jpg]
so in all today has been a very productive day
there are a few things i still need to get  but we will start on the paint tomorrow Smile
GTI6 Info
ripping back the paint to get to the rusty bits
quick coat of Kurust followed by a coat of Zinc primer then another primer then the top coat should keep the evil brown stuff at bay for a while
[Image: 20150811_132615.jpg]
[Image: 20150811_140511.jpg]
i was fealing smug a few days ago things were going too well!
well yeterday i lost a fight with a grinder fitted with a twisted wire wheel !
the thing kicked on the work it then lunched the tool back at me tangling in my tee shirt
to be honest i think i was very lucky to get away so light!
be careful out there with power-tools guys they can bite
[Image: 20150810_201237.jpg]
GTI6 Info
  cully's XU10J4RS cully 11 10,105 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 96,547 16-04-2016, 04:14 PM
Last Post: cully
