Dum-Dums Bianca GTi6
If you want a set of runners for that seat hit me up. I have some spare
(30-09-2012, 05:09 AM)C2K Wrote: Sparco greyhound?
Swapping the door handle is a right pain, mine snapped on the HDi a few years ago when i was in the petrol station with the pass side against the pump... fail.
lightweight dog for lightweight car lol
(30-09-2012, 07:29 AM)Matt Wrote: If you want a set of runners for that seat hit me up. I have some spare
No thanks cos theyll raise me back up again and i dont want that.
Im gonna make a better attempt at it at some point in the future but itll do for now.
So the latest weights
GTi6 Drivers Seat = 20600g
DTurbo Drivers Seat = 18600g
Drivers seatbelt = 2320g
Sparco seat, subframe and harness = 13000g
Drivers Seat difference = 9920g
GTi6 passenger Seat = 18600g
DTurbo Passenger Seat = 16600g
Passenger seat difference = 2000g
Passenger seatbelt = 2270g
Passenger Harness = 1330g
Belt difference = 940g
Standard backbox = 9800g
Aftermarket backbox = 4400g
Backbox difference = 5400g
406 Brembo callipers and pads (pair) = 7630g
Xantia V6 discs (pair) = 15920g
GTi6 Calipers and pads (pair) = 13000g
GTi6 Discs (pair) = 9920g
Brakes difference = 630g
Door Cards std pair = 5720g
Door metal parts = 250g
Door Cards Carbon Fiber = 2140g
Door Cards Difference = 3830g
Rear window glases (pair) = 4100g
Rear window seals (pair) = 1060g
Rear window plastics and bolts = 100g
Polycarbonate windows (pair) = 1240g
Rear window difference = 4020g
AC Compressor = 6720g
Front mats = 1230g
Fuse box cover = 40g
A pillar trims = 410g
Roof lining = 1570g
Rear interior roof light and clips = 140g
Sun Visors = 720g
PAS belt cover = 60g
Rear roof handles = 190g
Passenger airbag = 3000g
Airbag ECUs and wiring = 1430g
Front carpet = 6060g
Lower glove box = 1060g
Front door seal trimmings = 300g
Gear gaiter = 160g
Center console front = 1630g
Centre console rear = 730g
Centre console plastics and bolts = 250g
Tar (so far) = 810g
ADDITION Fire extinguisher = 2100g
Total for the above = 51.15KG LOST!
My shit weighs 51.15kg
Is that 51.15kg from the start?
I think if I had a wank right now it'd weigh about 51.15kg....
(30-09-2012, 09:36 PM)Scott Wrote: Is that 51.15kg from the start?
This is what I'm wondering...
No, that's another 51kg, already had ~90 out in the last post like this i think.
Nope
(01-10-2012, 03:56 AM)Poodle Wrote: No, that's another 51kg, already had ~90 out in the last post like this i think.
Correct
IIRC it was 87kg on the last load i put up so its almost 140kg off in total. (and i forgot to weigh the aircon rad and pipes)
I just need time and not insignificant amount of money to make it any lighter. Tempted by a smaller battery to relocate and need to strip down looms then its lightened engine bits, fiberglass pannels and i could probably shed another 10kg with a pair of proper fixed buckets.
Might stick her on the weighbridge at some point this week and see what it says.
So washed the car today, decided after playing with some black tape (that wouldnt stick very well) that im gonna paint a 1" strip pf the rear window edges to make them look more OEM.
Also over the last few days smoothed and painted my bonnet.
I cut the backing to the badge off then epoxyed in some bits of ally strip and box section so that I didnt need too much fiberglass. I then filled with fiberglass till just below the level of the bodywork and packed it in front and back so I only need a thin skim of filler
Then fillered, sanded, fillered, sanded, fillered, sanded, fillered, sanded and wet and dryed it to shape.
Then about 8 coats of primer and it was wet and dryed back and re masked then about 6 or 7 layers of top coat and thats how we stand.
The paint match is terrible, the paint i have is ph2 bianca and was a great match on my door handles but its miles out on the bonnet that is lighter and whiter being a ph3 item.
This picture dosent show how bad it is.
Anyway heres how she stands, need to finish repairing my fiberglass grille and paint it.
Oh and note the GTi badges have fallen off the sides cos i didnt like them without the 6s
Just need to wait for it to harden and its a week till im next off so then i'll go over it with the rubbing compound and try my best to blend it in. (dosent look too bad from a distance though)
Surely filling holes goes against your ethos?! Now you're going to have to remove a wheel
Looks good, will look so much better with black around the windows.
Gunna be nose heavy....
Although you can actually see te difference in paint from the whole bonnet compared to the wing. But only of you look hard lol
White seems to be a hard colour to match, 205's use different shades of white under the same name which is a pain.
Will you be joining me in the 50 shades of white team now?
Stage 2 XUD Sedan
(09-10-2012, 05:47 PM)Curt Wrote: Surely filling holes goes against your ethos?! Now you're going to have to remove a wheel
Yeah it is a little but buying a new badge when im eventually gonna have a smoothed lightweight fiberglass bonnet when ive got the money to go with the fiberglass grille thats in my garage. So its a temporary measure.
Cheers for the compliment though mate.
(09-10-2012, 06:02 PM)Matt Wrote: Gunna be nose heavy....
Yeah the bonnet is a terrible match cos its ph3 bianca not ph2. and yes nose heavy mate, esp when i get the saxo pump on.
(09-10-2012, 06:23 PM)strictly_derv Wrote: White seems to be a hard colour to match, 205's use different shades of white under the same name which is a pain.
Yeah theres at least 4 shades of bianca on mine if not more.
Just had a ninja late night delivery of oily bits to play with from The Thorne - Cheers Callum
Also shouldn't of gone to Scotts earlier. Spent more money that I dont have on shinys off the car hes breaking mainly to make mine look prettier.
My Little Slag Bianca is gonna be looking and sounding incredible for the Christmas meet.
What've you bought then...?
Curt on a completely unrelated note I've just noticed that the right hand side image of your car in your sig has been flipped (I'm guessing so the background seems to match more) but now that means the exhaust is on the wrong side!
Yes you are correct, it's so it works better... You're not supposed to point that out though Tongue
I should have done it with the picture of the front, but I thought of it after and couldn't be bothered lol
Scott you anus....
epic! this is going to be good. always been tempted myself to do this Smile
Love it
pikey as ever Tongue
what you doing with the plemun? can i have it?
Bodgetacula!
you using stock ecu? with all the original sensors like yani on the 6 forum?
If you want more info Maz who was asking about 106 rallye manifold for his 1.6 306 did the yani conversion on his old gti, it sounded epic but it didnt make much difference.
Looking smart dude really liking the build Smile nice work dude
Sweet as f*ck dude!!!
[Image: SDC10442-1.jpg]
(24-10-2012, 03:24 PM)Niall Wrote: Bodgetacula!
(24-10-2012, 03:32 PM)Fozzy Wrote: you using stock ecu? with all the original sensors like yani on the 6 forum?
These^^
It will sound porno though!
That was a smart work-around the guy on the 6 forum did with his Xsara VTS (?) I think it was.
Going to sound incredible
[Image: Sig500x130.png]
TBH i cant see many power gains without getting it mapped. Once again, this will fail and i have no faith in your abilities to make this work.
  Bianca White Phase 2 Gti6 Track & Fast Road Car Chr1sch 62 43,054 22-02-2016, 01:54 PM
Last Post: Chr1sch
  Dum-Dums VNT 2.1TD OEM+ Bianca Estate. (loads of pics and video now added) Dum-Dum 737 615,606 10-09-2014, 04:43 PM
Last Post: Dum-Dum
  The 2.1TD Bianca Sedan - Dum-Dums Project Cheap Dum-Dum 330 282,934 21-01-2013, 11:40 AM
Last Post: Dum-Dum
