Cully's Bianca 6 R150 YVM
I'll look for you when I'm home tomorrow darling x
thanks sweet cheeks
maybe this number 9227 23 ?
Loving the ride Paul, such a huge transformation and all the jobs have been done properly Smile
[Image: siggy1.jpg]
well i try my best
if thats not good enough i get someone else to do it Wink
i can tackle a lot of the jobs but some need doing by people with the correct tooling and experiance
Loving the attitude and direction of this mate, nothing as satisfying as doing as much as you can on your own motor
just been out and had a look at the drivers window
pulled out the seal and the top plastic guide is missing
guessing its dropped into the bottom of the door
if this comes detatched from the glass i suppose the pin clip is broken so no point taking the door card off and retreaving it?
am i correct in thinking it is item 2 in red on the drawing or is it handed left side and right?
[Image: drawing%20parts.jpg]
Yes.
5 characters.
Correct Paul. If you want to make the window nice and smooth, id suggest replacing the rubber ring that goes in the bottom of the glass as well. I did both on my drivers window and its perfect now. Passengers one still jumps about.
some more pictures are turning up from the twin exeter meet i went to over the weekend Big Grin
[attachment=13298]
[attachment=13299]
Oooooer Wink
Apart from the wheels thats a lovely looking Rallye you've got yourself.
Rallye???
(03-02-2014, 08:04 PM)maffy Wrote: Apart from the wheels thats a lovely looking Rallye you've got yourself.
no coloured lion strips on this Vixen
it a Saucy 6 Wink
There appears to be a young lady in your "saucy six"...
(03-02-2014, 08:28 PM)Tom Wrote: There appears to be a young lady in your "saucy six"...
shhhhhh Don't tell the wife! Wink
had a very productive day yesterday and today
repaired the estates n/s arch buy welding in a patch on Saturday
and..
today it the six's day
started off today by clearing out the garage putting away all the tools
so i had some space to weld......
decided to repair the drivers window as i collected my plastic widow guide from Peugeot on Friday
easy job basically pull out the side seal, clip plastic guide to window, slide seal over guide and work it into the door channel, done now have working drivers window again Smile
next job was to tackle the drivers seat, as the frame was broken,
so removed the seat from the car, into the garage.
took the seat squab off the base frame so i could see the broken tube and frame
realigned up the tube and welded it back together
cleaned it up and lewis gave it a coat of paint on the welds
the seat cushion base has been digging into my thy so decided to take the leather cover off to see if i could improve it.
to my surprise it looked an easy fix as the foam had broken away and was breaking up,
so out came the duct tape to cover the foam to give it its shape back,
now to find something to pack up the side wings, as they are supported on bars which were digging in me......
Lewis had a great idea of using the wifes washing up sponge's
so one of these were duct taped into the slot where the bar sits into the foam cushion.
leather cover was refitted and all fitted back into the car
test fitted and it seams to be quite a good fix the side support has firmed up loads and now don't dig in my thy
These will be mint by the summer Smile
[Image: siggy1.jpg]
Nice idea about the padding on the seat frame!
Where abouts had the seat broken down the bottom then?
the seat was broken in two place's very close to each other
1st was the main tube at the rear, the one in the picture as it bend down was totally detached
2nd was the hook plate was broken off the main tube above
with both broken it made the seat very unstable into corners Wink
its a lot better now
[Image: DSCF1256.jpg]
Jesus, I've never seen that before. Good job you fixed it really. Could cause the farmers to flare up! lol
its been play day today
so i decided to replace the standrad rear engine mount for a vibra tec mount
had to strip the long drive shaft out, so then decided to replace both driveshaft oil seals
as the gearbox oil was drained
fingers crossed that will stop the dots on the drive Smile
[Image: DSCF1292.jpg]
[Image: DSCF1293.jpg]
[Image: DSCF1291.jpg]
went for a drive certanly feels tighter theres a little more vibration up front when on tickover but not noticable once moving
They are excellent mounts. Even though i seem to be breaking everything since i fitted it lol. Feels great when your hooning and on/off the clutch really quick up through the gears!
Your crank pulley looks like its seen better days lol!
been for a little drive tonight
thought id treat the girl to some V-Power fuel
all i can say.... HOLLY FECK its a different car!
(02-03-2014, 10:11 PM)cully Wrote: been for a little drive tonight
Really? I held my hand on the vpower pump for about 5 seconds before filling up with normal fuel haha
SHHhhhh Don't tell the wife! whistle
[attachment=14405]
Which ones are they? I just picked up a pair of B4's.
they are B4's Wink
out of interest how much were yours?
(18-03-2014, 09:46 PM)cully Wrote: they are B4's Wink
£35 with postage. They aren't new like yours though, it's the set Piggy was selling.
today was a very productive day
fitted my new rear shocks, one of the old ones was fuggered, all the top bolts were siezed bastard job to remove them
all back together.
had to take down the spare wheel cradle to gain acsess that bitch was siezed too, gut it off with a disc cutter
good job i found that now not in germany!
and the sad news, sad sad news
ive fitted a standard exhust to the car including CAT Sad
i have only done this for the germany trip just to quieten the car down
I don't like it now its not the car i wanted when i saw it first
I can even listen to tunes on the music box not used to this
  cully's XU10J4RS cully 11 10,226 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 98,089 16-04-2016, 04:14 PM
Last Post: cully
