Matts Onyx Rallye. 182.1bhp & 154.5ft/lb Wilwoods & axle arrived! Welding finished!
(09-04-2016, 08:41 PM)Ben_w Wrote: You my friend, need to invest in some Deox c gel.....
That aside, fair play. That's a shed load of work so far. Keep it up.
I cant find anywhere locally that sell its Sad Cheers buddy, it might one day be somewhere near the standard of yours!
(10-04-2016, 04:18 PM)allye Wrote: Under side restorations have got to be one of the most satisfying things to read and watch unfold!
Wierd but true.
Oddly satisfying to do aswell Big Grin
Team Cyril
You.won't find anywhere locally that sells it....just buy it direct from the Bilt Hamber website. They deliver it...
(11-04-2016, 09:10 AM)Ben_w Wrote: You.won't find anywhere locally that sells it....just buy it direct from the Bilt Hamber website. They deliver it...
Ah i see! im usually more of a cash buyer but if needs must! Big Grin  cheers for the tip
Team Cyril
This is now on hold after someone decided to pinch my trailer the other night. It will continue once i have suitably secured my unit and the surrounding yard.
Team Cyril
Yeah so "on hold" lasted long..
[Image: IMG_6429_zpsccvn24sz.jpg]
[Image: IMG_6430_zps51thsbld.jpg]
Team Cyril
Get into those box sections behind the bump stops whilst you got everything out of the way.
You'll regret not doing it
These horrible feckers....
[Image: IMAG1638_zpshu37bmsw.jpg]
[Image: IMAG1639_zpsehh5oppb.jpg]
Thanks ben, what did you use? i was looking at those rust traps yesterday and thinking i might invest in a dremel tool with a long wire brush cup attachment?
The car is being fully stripped underneath (much inspiration taken from yourself sir!) so the bumpstops will be removed and everything in & around that area will be cleaned and painted Smile the floorpan will be going back onyx but arches are staying white, i like the clean / motorsport look it gives.
Team Cyril
Exactly that....local toolstation place I think it is do a box of wire brush attachments for drills. I used those. Dremel stuff will be even better I'd guess. Chuck loads of Deox gel in there too.
Be prepared for the bump stop bolts to shear. In that blind hole is a welded captive nut the the bolt under the bump stop (which holds the cup) bolts into. As they are rusty as feck, I sheared one bolt, even taking it easy and undoing, then doing back up a bit, then undoing some more.
Drilling it out was fun.... :/
(02-05-2016, 08:54 AM)Ben_w Wrote: Exactly that....local toolstation place I think it is do a box of wire brush attachments for drills. I used those. Dremel stuff will be even better I'd guess. Chuck loads of Deox gel in there too.
Cheers for info mate much appreciated Smile
Yeah we replaced zakks (ozonehostile) gti6 bumpstops, pig of a job!
Team Cyril
I had to drill the bolt out of my bumpstop cups too aha, spoox sell new cups if yours are rusted into nothing like mine were.
I'm glad that coming around mine yesterday gave you inspiration to do your own car for once lmao
(02-05-2016, 09:08 AM)ozonehostile Wrote: I had to drill the bolt out of my bumpstop cups too aha, spoox sell new cups if yours are rusted into nothing like mine were.
damn you sir! i was supposed to be meeting that smart looking bird then i looked at the clock after i was covered in rust dust and white hammerite lol
Team Cyril
lmao
Cockblocked by my rallye.. well played rallye! well played.
Team Cyril
Just had a look.....£23 a side isn't too bad actually.....my cuos hadn't rusted away, they were still in pretty good nick...still, out of the factory they weren't pitted so I'll be buying a pair of those new ones! OEM pug too
 Yeah I was pleasantly surprised when they arrived in the Peugeot bag
Well i suppose this is due a small update,
Having done a few small jobs to this recently i have now discovered more rust issues on the front end, namely the inner strut turrets where it meets the inner wing, its going to be an absolute pig to repair it in situ, very disheartening if im honest so for now the car can carry on sitting on axle stands feeling sorry for itself while i decide what course of action to take with it.
Team Cyril
(23-05-2016, 03:38 PM)Matt-Rallye Wrote: Well i suppose this is due a small update,
I'm really sorry to hear that Matt. I was looking forward to seeing her again at FCS, but it's got to be done right. Don't lose hope, take your time, go get drunk or something. That usually cheers me up!
It's my anniversary with the missus on FCS day, not going means I'm actually going to have to do something for her! That Rallye has cursed us both!
eugh what.... team black rallye is getting thin on the ground! Im sure mine will be worse than whatever you have found.... but ignorance is bliss.
Yeah I don't dare look at mine
CLUB RALLYE
Some slight sliver of hope....
The newly found rust isn't as bad as first thought, but still requires more time and attention than i can spare just at the moment. Hopefully i can get abit more done over the weekend and find some motivation for it.
Team Cyril
(27-05-2016, 10:44 AM)Matt-Rallye Wrote: Some slight sliver of hope....
Good luck!
Good luck!
Cheers fella! Was genuinely close to giving up with it but i suppose it doesn't really matter how long it takes, the end result will be worth it Smile
Team Cyril
Black rallyes FTW. Don't give up, show it who's boss of it.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Been meaning to update this..
After more poking around the front end i have concluded the rust issue is actually alot less worse than it looks and isnt actually causing any agro, just needs sanding and painting ASAP before it does develop! luckily i have caught it early on Smile Big sigh of relief there!
Just waiting for access to the ramp really to give the underside the same treatment iv'e given my red rallye recently, then i can start bolting all the shiny bits on and get this car back how i want it and on the road! Big Grin
Team Cyril
Thread revival!
Still got this, its still awaiting attention but lo & behold its more solid than my red one so will concentrate my efforts on getting this one repaired for this years show season and so i can actually enjoy it once again Smile I have an overkill stash of parts awaiting to be fitted inc the wilwoods, bilsteins, stef refurbished rear beam and some freshly powdercoated goodies & polybushed wishbones etc etc just need to make some time and exert some effort!
Then it should just need a cambelt & service before chucking it in for an MOT Smile
Team Cyril
Good news. Get her done.
        I Don't Have A 306.
(07-03-2017, 08:20 PM)Danny Wideboy Wrote: Good news. Get her done.
Cheers mate Smile I was talking to a fellow collector of rusty peugeots last night and he made me an offer i couldnt refuse on the red rallye so thats now as good as sold! Currrently in talks for a bulk deal on the cossack grey S16 too as i simply havent got the time these days to devote to so many projects.
Team Cyril
Be good to see the black rally back on the road. Shame about the red one going though.
Eugh matt you were so close to having them all done Tongue
You can never sell this old girl though... She's a trooper!
  Phase 1 GTI6 - Onyx ginge191 2 3,123 01-04-2026, 08:48 PM
Last Post: ginge191
  Matts cheap cherry rallye Matt-Rallye 15 14,805 02-01-2018, 08:45 AM
Last Post: Matt-Rallye
  Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. Matt-Rallye 29 26,032 10-05-2017, 12:49 PM
