Stage 3 XUD project
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
Stage 3 XUD project
Fair enough :-)
Td04 is on seems to boost up nice, still got fuel way down atm, but it dosent die at 3500 anymore, so must of been wastegate/actuator issue on the t25..
[Image: 459ab4e1.jpg]
[Image: f6a9ecde.jpg]
only pics i took really, might not look pritty but its down the back out of sight and it works Wink
what the hell did u use to put elbow on lol
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
A gas bottle
need to get my elbow done so i can get td04 on but cant get elbow off t2 wont bloody move aha
Glad you got it sorted mate looks good
Current cars
Subaru Impreza 2.0d - Daily
Whats she run like now?.... get fookin pump sorted!!!
studturbo Wrote:need to get my elbow done so i can get td04 on but cant get elbow off t2 wont bloody move aha
you can swap a engine but you cant remove a few boltsn :roll:. told you get a impact driver and wd40
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Dave nothing wrong with the pump, it pulls all the way round now.
Some pics to keep the thread alive..
[Image: e224b03d.jpg]
[Image: cae44b37.jpg]
[Image: 812958bd.jpg]
I want your wheels.
Captain Standard
The car is very dirty in the pics, wheels are full of brake dust.
Got some new catch tank hoses today along with an inline filter, also jazzed up the power steering pipe with the spare catch tank hose..
[Image: 0365a5f9.jpg]
[Image: 78b29cd9.jpg]
How is it with the in-line filter?
Stage 2 XUD Sedan
Have you added it in addition to the current filter?
It drives exactly the same, and no the old filter and housing are nomore only the one under rear seat is left
looking good padge. by the way your 2 clips missing off your grill. Big Grin
I know lol
kingy Wrote:looking good padge. by the way your 2 clips missing off your grill. Big Grin
factory standard, no car has a grill intact..
Mine did! Sad
So today went to jenks house, and he kindly rerouted my battery and mounted my oil cooler.
[Image: cd15e695.jpg]
[Image: ec569d44.jpg]
Have you got fans on the oil cooler or something?
Even if you have, cant see it being very effective in there as the airs hot / its just gunna circulate the same hot air around and around....
Was something that I had discussed with Kyle the way it's set should be enough room below to get a cold air feed up into I did also mention about possibly a fan too. But the cold air feed or fan is upto Kyle now
www.prestige-auto-care.co.uk
Hm yeah but theres not gunna be naff all air flow there....the engine bay just turns into a big warm air space....all the hot air from the rad / engine just heats it up, like that install unless totally isolated is going to make no difference :S
So you relocated your battery at expanse of cable / battery box etc, and spend 100+ quid on an oil cooler, and fitted it where it wont make much / if any difference at all lol....
Have you still got your stock cooler into the coolant system?.... cos having it there will overheat due to lack of airflow as soon as you push anything, no offence kyle but thats not very race spec Wink and anyone who looks at that will wonder why you've done it because it provides no advantages at all?
because racecar
because racecar ? Smile Yup that is completely and utterly pointless/has the opposite effect entirely!
[Image: Atterz.jpg]
As Dave said, hope you have left the stock water cooler fitted, as the stock cooler does ALOT more than you might think, and theres no way on earth that is going to manage that, let alone offer a boost, so you will be cooking oil if you have bypassed the stock bit, which if you havent, also defeats the point lol...
Just get it mounted somewhere in air stream them ur money is doing its job, atm its just wasted...
Dan! Wrote:because racecar
lmao
+1
  306 Stage 2 HDi Progress/Project. mcglynn 139 113,364 31-12-2018, 02:09 AM
Last Post: Allistairc123
  Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. Matt-Rallye 29 25,069 10-05-2017, 12:49 PM
Exclamation PH1 genesis STDT sedan! Stage 2 soon be stage 3 GT20 strictly_perv 127 75,202 16-06-2014, 05:06 PM
Last Post: MissTap_GTI6
