09-09-2013, 09:13 AM
Hi, is there a spacer that goes on the stud through the gearbox mount ive just taken mine off and there is no spacer, & should the spacer be a tight fit in the mount. Thanks
need a quick answer gearbox mount
Not sure what you mean about a spacer, the gearbox mount isn't a tight fit on that stud, even when new.
09-09-2013, 09:32 AM
It supposed to sit on the stud where the 19mm nut screws on to, i'll post some pics later
09-09-2013, 10:00 AM
Check it's not stuck in the mount?
09-09-2013, 10:41 AM
There is a washer UNDER the stud, where it fits into the gearbox. There is a small washer with a flat on it which sits on top of the mount before the top nut goes on.
HDi Owner for 200k/9 years
09-09-2013, 10:43 AM
Yes there should be a spacer, couiple inches long bit of steel tube, likely stuck in the mount...it should be a snug fit inside the rubber part of the mount
09-09-2013, 12:19 PM
Orly?? None of mine have been a snug fit, that explains why none of the mounts have been stiff enough for me...
09-09-2013, 12:28 PM
If you cut it down a tad and tighten it tight you can make them stiffer, redneck modding lol.
09-09-2013, 12:36 PM
Hahahah nice!
Tbh I dont really see the issue with bolting it straight to the chassis. |
Gearbox mount issues | dr_jekyll | 2 | 1,396 |
26-10-2018, 12:52 PM Last Post: welshpug |
Gearbox engine mount | DeeTurbo | 15 | 2,892 |
17-06-2016, 08:46 PM Last Post: DeeTurbo |
I may have the answer to our stage 2 clutch woes. | Oil-burner | 42 | 10,032 |
21-02-2013, 06:16 PM Last Post: Arron |
