Sean's (& Ed's & Scott's) Astor GTi6
#91
When I had the 1.6 I had power problems where I'd go to set off at junctions it would bog down stutter till it reached a certain point and bang all power would kick back in. I tried all sorts coil packs, fuel filters,pumps ht leads, lambda etc etc in total spent couple 100 quid turned out to be the coolant temp sensor which cost a £10 iirc something to do with the ecu reading wrong temps and having wrong amount of fueling.
Apparently more common on vags but I have seen it allot on pugs doesn't flag up engine management and often doesn't flag error codes.
www.prestige-auto-care.co.uk
Check this out pretty much describes how important the sensor is!
http://www.autoshop101.com/forms/h32.pdf
/goes to buy a temp sensors.
I have the same issue.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Same lol
Genuine CTS from Pug was about £18 when I got one, the one with the green plug. Adjusts fuelling depending on engine temp to help with cold starts especially. Gives similar problems to a collapsed cat of knackered lambda, tbh for the price of a genuine one i'd always fit a new one just to make sure you know it's a good'un.
cwspellowe Wrote:Genuine CTS from Pug was about £18 when I got one, the one with the green plug. Adjusts fuelling depending on engine temp to help with cold starts especially. Gives similar problems to a collapsed cat of knackered lambda, tbh for the price of a genuine one i'd always fit a new one just to make sure you know it's a good'un.
Last time I looked they were 35 quid!!
Seriously worth doing though. As said make sure you get the green one. Blue one is for the gauge on the dials and brown is for the fans controller
You can thank me all later if it works........ ninja
Fark really? I bought one last year for £18 from the Pug garage next door to my parents in Blackpool. Had a few in stock too. Can't have gone up that much can it?!
Ed Doe Wrote:Oh for f*cks sake!
It doesn't sound tappy you bunch of knobbers!
Go troll someone else! lol
@Jenk; does the temp sensor cause these issues exactly tho? I thought it caused a wandering idle?
Thats the spirit. If you tell yourself it's not tapping often enough then eventually you'll believe it.
I had that problem with the Skoda when I got it. Turned out to be a gunked up throttle body Wink
The throttle body looks pretty clean tbh Liam, and it opens/shuts smoothly without any odd resistance, so I'm pretty sure it's a sensor issue...
So is this the one I'll need; http://www.eurocarparts.com/ecp/c/Peugeo...86e&000572
Or is it worth sucking it up and going for a genuine pug one?
Get a genuine one imo.
[Image: sigi-2.png]
If you do decide to clean it out mate, make sure you get a new gasket. I didn't, and it caused 9mpg until I sorted it lol
Ed, you can check if the CTS is working properly with a multi meter in about 5 seconds. Worth it before shelling out even if it isn't much. I didn't bother taking mine out of the engine but just checked it when the engine was cold and when up to temperature.
[Image: CTS.jpg]
[Image: sigjpg.jpg]
Serious.
lol I spoke to my mate the service manager at broadbridge heath peugeot (he runs a tarmac rally 205; hero!)
TPS: £129.87+VAT
CTS: £13.29 + VAT
MAP sensor: £42.71 + VAT
Looks like I'm gonna try the multimeter, then the tps & map sensors and finally something a little birdy told me today it could be; cam timing...
Guess who has a multimeter whistle
Scott Wrote:Guess who has a multimeter whistle
I do. In fact I had 3. Blow me and you can use one.
Cam timing? really?
/sigh
/padantic
1. Fooby's Car
1. Learn to Car
Fooby Wrote:Cam timing? really?
/sigh
/padantic
Fooby do you even know what cam timing is? In fact, do you even know if your car has a cam(s)?
/sigh
/padantic
yes, i know about cam timing.
1. Fooby's Car
1. Learn to Car
Actually Fooby, I think you'll find it's spelt 'Pedantic' :roll:
RIGHT, update!
I. Am. A. Tool.
So I got home early from work so decided to have a fiddle with the car...
Thought I'd go pull the map sensor off and see if I could clean it at all. When I removed this, it looked fine. Well actually it looked a lot like th sort of component that wouldn't respond well to being doused in WD40. So I put it back.
I then thought "I wonder what this TPS looks like; if I can prod it a bit and feel if anything's wrong...."
This thought was quickly followed by "Hmmm that White plug looks a lot like it should go somewhere.... and I've just felt where...." (Giggidy)
When fitting the ptfe inlet gashkit @ Grants the other day, I'd been rushed (this is my excuse, I'm sticking to it) to put it back together to move the car out the way. And in the rush, I'd forgotten to plug it back in.... Doh
Which explains Grant why my car was so Jerky the other day when we went out for a drive. I thought it was just I wasn't used to it, but it wasn't actually running right at all!
Dick.
Niall Wrote:Dick.
this
1. Fooby's Car
1. Learn to Car
Fooby Wrote:
Niall Wrote:Dick.
this
well if I hadn't had to stop working to catch all the toys you were throwing out your pram i'd have done it proeprly!! :roll:
Nick work lol
LMFAO........... :clap:
Team Orange Engine Bay
Nice work Ed.... :facepalm:
[Image: Sig3_zpscd005eb1.jpg]
...what a knob.
FLOL! Rookie error!
Ed Doe Wrote:Actually Fooby, I think you'll find it's spelt 'Pedantic' :roll:
RIGHT, update!
I. Am. A. Tool.
You were probably better off, for your own dignity, just not telling everyone that!
  Frosty's astor GTi6 Frosty 20 16,357 26-07-2018, 05:12 PM
Last Post: Frosty
  Sean's Diablo HDi Stage 2 168bhp & 290lbsft Just Sean 383 231,863 08-05-2013, 11:47 AM
Last Post: Poodle
