Bosch Idle Problems with smoke
Ben Jay Wrote:
Dan! Wrote:Is the pump diffinately in the bosch mounting studs on the bracket and not the lucas ones?
the pump arrived on a cradle that i just assmued was the correct one. has any one got both cradles to hand and take a picture of the differences?
the only difference is the position of the pump mounting studs, that is it!
Team Orange Engine Bay
#32
i want to make sure they are in the correct possition and the guy hasnt sent me a lucus cradel
#33
This is hard work Ben Doh lol
Can you get us any close up/decent images of the left hand side of the pump where it bolts to the bracket?
#34
will do. lol i cant do very much during work thats why theres so many questions!
i really appriciate your help as i know im a pain in the arse!
#35
Ben Jay Wrote:i want to make sure they are in the correct possition and the guy hasnt sent me a lucus cradel
do you have a LUCAS one there?? if you do compare them, are the studs in the same holes as the Lucas one?? if they are then its the wrong bracket, if they aren't then its the correct bracket, mystery solved...............at the end of the day the bracket's are identical aside from the position of the studs!
Your really not forthcoming with information are you lol
#36
could not replacing the injector seals be a cause?
#37
You'd know about that, you'd hear a "chuffing" noise from the injector seating area.
If you want, get some soapy water and pour it around the injector seat area, see if it bubbles.
#38
well they are only 38p each so going to replace them any way
#39
Ben Jay Wrote:well they are only 38p each so going to replace them any way
New engines are only around £150, why not just change it?..................
#40
lol after all this it will turn out the pump has had it and ill have to stick the lucus back on!
#41
how have you not sorted this yet?! lol
#42
[Image: 3DaysLater2.jpg]
#43
lol
Bananalad Wrote:[Image: 3DaysLater2.jpg]
And the rest............ more like weeks! lmao
#45
Ben Jay Wrote:will do. lol i cant do very much during work thats why theres so many questions!
Surely it would be a good idea to wait until you can act on responses rather than ask every random combination that it could possibly be?
#46
Right given up now. Going to let kris work his magic on it over next weekend
  more bosch problems blinkyeatu 9 4,848 24-08-2015, 07:57 PM
Last Post: blinkyeatu
  Bosch pump conversion problems Farmer-Glen 16 8,617 16-09-2014, 07:08 PM
Last Post: Farmer-Glen
  Bosch conversion problems mikes 16 7,899 13-08-2014, 07:35 AM
Last Post: mikes
