VAGAGAY K04- it's boosting!
#61
[Image: IMAG0824.jpg]
[Image: IMAG0825.jpg]
[Image: IMAG0826.jpg]
[Image: IMAG0827.jpg]
[Image: IMAG0829.jpg]
Just need to get some counterunk bolts and a big drill bit to make a countersunk.
Getting there...
Stage 2 XUD Sedan
#62
Looks a neat job this.. That elbows off a k14 is it. Any chance it could be too restrictive coming large dia out of the turbo and then a sudden step to that. Not criticising btw, I have similar on my td04 just and I'm concerned that it might just be holding it back?
#63
I'm sure it is TBH with you, i'm like to try ground out the holes more so it will flow a bit better. I'll see how this one goes but I can always make a better one as its all just bolted on.
Stage 2 XUD Sedan
#64
You don't need countersunk bolts, just drill a hole big enough for head of the bolts you have, weld around them and then grind off the excess flush Smile
Team Orange Engine Bay
#65
strictly_derv Wrote:I'm sure it is TBH with you, i'm like to try ground out the holes more so it will flow a bit better. I'll see how this one goes but I can always make a better one as its all just bolted on.
Yea I'm really thinking of making another for mine, it'll be the MK3 version! All bolted together, but I still have to take the turbo out to change it!
#66
mark_airey Wrote:You don't need countersunk bolts, just drill a hole big enough for head of the bolts you have, weld around them and then grind off the excess flush Smile
Or just weld the elbow on from the start and not bother with any of the bolts at all :p
#67
this. Tongue
#68
That does pose an access issue though! so make sure the elbow is removable somehow! In this case tho the elbow coulda been welded to the flange like how I did it before.
#69
I've already ordered some countersunk bolts so and I don't have a welder so I'd rather bolt them on Incase it needs adjustment which is likely
Stage 2 XUD Sedan
#70
How have you set your angle??
#71
Angle of the down pipe? I've lined it up with the K14. All by eye so expecting fails :think:
Stage 2 XUD Sedan
#72
Hm as long as you've lined it up with something so the downpipe is around the same as stock and not just dilled it anyold way... theres probably 15-20° of freedom on the flange.
#73
Yes it's as close as I could get it by eye to the same angle of the the k14. I'll be getting it all fitted upto the spare engine to be sure everything else lines up.
Stage 2 XUD Sedan
#74
If you had something to ref. to next to it to make sure you have your up/down and correct length of elbow then should be fine, get 'er changed wanna see some boost!!!!
#75
I'm waitin on some bolts and drill bits first so won't be done till next week :violin:
Stage 2 XUD Sedan
#76
strictly_derv Wrote:I'm waitin on some bolts and drill bits first so won't be done till next week :violin:
Oh come on man...........we all want to see the results Tongue
#77
I now need to get hold of either a countersunk drill bit of a big drill bit :evil:
Will I need gaskets for this or can I just use gun gum?
Stage 2 XUD Sedan
#78
Just use paste, be fine, especially as you haven't welded plates to make them warp to hell.
[Image: sigi-2.png]
#79
strictly_derv Wrote:I now need to get hold of either a countersunk drill bit of a big drill bit :evil:
You just want a big drill so the bottom of the hole is as flat as you can so the bolt can sit against the face flat Smile
Exhaust paste is fine, I used Bosal exhaust assembly paste stuff but meh, its all the same idea lol
#80
Would have been alot easier to just drill / tap the holes and use studs or just do what me / mark did and weld / grind the suckers in.
[Image: sigi-2.png]
#81
darrenjlobb Wrote:Would have been alot easier to just drill / tap the holes and use studs or just do what me / mark did and weld / grind the suckers in.
Thats what he is doing AFAIK Darren, home made studs FTW Smile
#82
The threaded hole method occurred to me just after I drilled the last hole Doh
Stage 2 XUD Sedan
#83
Rather than using the 306 exhaust elbow could you not have made a better downpipe?
Ie Use the adaptor plate, drill the centre hole out to 3"/ 2.75"/ 2.5" and weld a bigger dia pipe to it and along with a flexi pipe you will have a decent flowing exhaust?
#84
Trust me its alot more hassle that its worth to make a bigger downpipe, you need to get the same flange size anyway, and then your defeating the purpose...
#85
In fairness, the stock 306 DP is a bag of crap for flow, but doesn't make that much difference.
#86
Ruan Wrote:In fairness, the stock 306 DP is a bag of crap for flow, but doesn't make that much difference.
Thats what I mean though, in most applications where the downpipe isnt big enough causing restrictions the pump is failing anyway.... and usually if the turbos big your not getting smoke anyway, so no issue!
#87
Dave Wrote:Trust me its alot more hassle that its worth to make a bigger downpipe, you need to get the same flange size anyway, and then your defeating the purpose...
Not sure i understand about the flange size Dave?
Why mess about with different bolt patterns when you can weld directly to his new machined plate and have a decent size exhaust. Fair enough it isnt going to improve it drastically it just seems a "cleaner" way of doing it.
#88
I've been proper slack lately!
Just bought a 20mm drill bit to bore out the holes.
Stage 2 XUD Sedan
#89
:yawn: come on..
Slacker.
On the 306 waiting list.
#90
Just waiting on the post-man now Popcorn
It will be on before FCS though!
Stage 2 XUD Sedan
  Lucas K14 Boosting 2 Bar daveylennon93 9 6,734 01-01-2015, 01:42 PM
Last Post: daveylennon93
  top mount td04 not boosting DagDag53 24 13,123 04-12-2014, 09:24 PM
Last Post: daniel.mountain.7
  XUD *over boosting* ? ADV_93 6 5,415 01-08-2014, 08:21 AM
Last Post: Ruan
