Paul's 330i
There just seems to be a large different on part load to fill load. I lift off slightly and it shoots off like a rocket
Still can't get launch control to work. I'll have a look at the settings again
I know the feeling, i have a similar behaviour. I think i recall someone saying you can actually make more power on the part load maps than full. The ECU can be quite quick to pull timing
Tried the isaless mod twice worth no joy. But I think I may of solved it thanks to the E46 forum
Refined the vanos tweak and wow mighty difference
Nice, was that still the part load maps?
Yes indeed
Still here, still lurking daughter taking up a lot of the time.
Clutch is slipping a bit now,so the rear suspension bushes need renewing. Other than that it's being spanked every where and I'm still tweaking the ecu.
  Paul's Evo V paulgtt 3 3,298 06-09-2017, 08:30 PM
Last Post: paulgtt
