rear brake bias replacement
Ok so my zx has rear discs and uses two inline pressure reducers on the rear hardlines - no load compensator.
These are no longer available, or stupidly hard to find / expensive.
Suggestions for replacement?
I'm thinking either using a brake bias valve up near the MC and running new hardlines to rear from one port with a T piece - note would remove diagonal split in system.
Or using a load compensator - maybe just tied up out the way so it doesn't move.
Any suggestions for either?
and for aftermarket brake bias valves?
thanks
same as a late 205/309 so readily available not too expensive.
service box says NFP
part number 1
GSF which I have bought from in past don't seem to stock any longer, or ECP
(10-10-2016, 10:24 AM)welshpug Wrote: same as a late 205/309 so readily available not too expensive.
been nfp for about 15 years lol.
try mr auto.
or a bosch stockist, got mine from one for the zx 16v. shorts auto electrical in cardiff.
will probably need to find the bosch reference number first.
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 12,890 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 3,868 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 5,776 24-04-2018, 07:11 PM
Last Post: Ben
