Paul's 330i
Paul's 330i
Picked my new car Saturday , big thanks to Greig  for the lift .
Bmw e46 330i touring in manual!
Seemingly in good condition, going to reseal the dual vanos and do a service.
Drilled a few holes in the air box to free it up a bit, standard air intake ducts are tiny
Going to sack off the clutch delay valve and look at either an auto differential or incorporating a 325i diff iinternals into mine, or a M3 diff/subframe etc
Did the "golf tee" mod for a laugh and the exhaust sounds mental
What does the golf tee mod involve? Any pictures?
Blanking off the vac line feeding the actuator flap in the back box, so both exhaust pipes are open
Noice. Get a video!
Needz moar piktorz!!!!
Exhaust mod sounds awesome for a free mod.
Literally the best free mod on these haha. Vanos seals is a good shout, can recommend a good company that are UK based if you haven't looked into it yet, makes a huge difference to general driveability.
And yeah more pictures needed
Happy doing the seals myself
but yes impressed so far and I'll get some pics
Yeah i just meant a company who sell the upgraded seals. X8r. Did my seals not too long ago myself using one of their kits, not too bad to do
Ah gotcha , I'll give them a research
Changed the plugs earlier, hopefully liven it up a bit
Stripping the 306 tomorrow
[Image: IMG-20160925-WA0012_zpson0ynfba.jpeg]
Pesky clutch delay valve removed
Where are the pics of the car!? Tongue lol
Be patient Tom ffs
its been a hour? where are the pics?
Vanos seal kit /rattle rings on order Smile
[Image: 20161002_142411_zpslxpsynov.jpg]
[Image: 20161002_144859_zpsh4eqjsf6.jpg]
[Image: 20161002_150207_zpsgjbnwxay.jpg]
[Image: IMG-20161002-WA0007_zpsz4xjk9zj.jpeg]
Did the vanos seals on it today, pretty easy to work on Smile
Haven't taken it for a drive yet.
Needs a new expansion tank and oil change
Nicely done. Personally find these quite easy to work on too, don't understand why some people say they're such a pig.
The seals take about 300 miles of driving to break in fully, it would also be worth resetting the engine adaptions too for maximum effect. After getting a 'cheaper' expansion tank it lasted about 3 months before splitting again.. went for a HELLA/BEHR one in the end which is much much better quality.
do the pas pump on and thermostat on a 318 then have a think about how eay they are lol
mostly not too bad though.
Lucky enough I only need to work on mine/other halfs cars haha. Is it not similar to the 6 cylinder where everything's up front?
I just find that although yes stuff needs to be moved out of the way for access, it's just very well thought out. For instance, removing the rad fan setup on my car is 1 plastic pin clip and a single torx screw and the entire fan unit and shroud comes out in one.
no, the gearbox is in the same place so instead of 1/3rd of the engine being under the scuttle, half of it is lol
What do you mean by engine adaptions midnightclub?
As you drive over time (potentially years depending on when it was last reset) the car 'learns' how it's driven and stores this in the ECU. Always change this every time something major is changed so it recalibrates to how it is now. You can do it manually, I think it's like turn ign on, hold throttle to floor on/ff like 3 times and then ign off - search to see if that's right though.
Or you can reset it using INPA (if you don't have this then it's probably the best £30 ever spent)
[Image: IMG-20161005-WA0004_zps8pgok7ff.jpeg]
How much and where from mate? Need one of these myself
What is it though?
Known as a steering guibo, they're made of rubber when OEM and over the years wear giving you 'sloppy' steering around the centre of the wheel. Replacing it with this will get rid of the play around the centre and make turning more direct
Type in on ebay e46 steering coupling
For e46 though
Seems as though I bought the last one
Yeah can't see it now, will have to keep an eye out for one
I'll send you through the name of the company
  Paul's Evo V paulgtt 3 3,072 06-09-2017, 08:30 PM
Last Post: paulgtt
