19-04-2016, 11:38 AM
Chemical metal reet
Project onthecheap
19-04-2016, 12:59 PM
(19-04-2016, 12:03 PM)Eeyore Wrote: A cracking find there... Yeah Something to get my head round for fixing Wishes for more power...
19-04-2016, 01:56 PM
Sunny this evening...so did a bit cosmetically to the old gal...while I wait for a belt.
Got numberplate lights done and numberplates. Made a huge difference on the look of it. So much neater. Pair of genuine peugeot numberplate fittings, covers and lamps £5.70 delivered! Win. £18 for both plates. Also debadge rear and sides. Also fitted little trim under handbrake, the cowling around the steering column which was missing and properly fitted the stereo which was just slotted in. Pics: And the need to next fix this: And paint this black: Also on list for next couple days is fit the new aux belt, yet to arrive, fit brand new pirrelli and the 10mm fuel lines...banjo also arrived: Wishes for more power...
21-04-2016, 03:55 PM
Got the "new" pirrelli on there today. Started the 10mm fuel lines but not finished that yet.
22-04-2016, 06:39 AM
Good stuff piggy, this is the great thing about 306s on a budget it's still surprising how much you can do to these cars
Made mistake of ordering m14x1.5 banjo/bolt for the bosch inlet...need a m12. Silly tom306 for saying m14 on a very old thread i found in archives! Teach me for being lazy and not just measuring it.
So 10mm lines will have to wait their completion till next week. Then hope to sort the loom(fixing rpm issue), fit the mint steering wheel that arrived today from Jonny, gut the cat and do a decent job of the exhaust and its ready to go. Found this while cleaning the pickup.....worst I've ever seen... Trickiest bit of fitting the 10mm line...donated from the racetractor is at least done... Wishes for more power...
Having "issues" trying to get the rpm gauge to work...
But got some touch ups done on the back end: Also fitted a "mint" steering wheel...its not so much but its better than the old one! Exhaust next... May have to leave the rpm gauge issue to another day...the new owner loves wiring diagrams...so he can enjoy that one! ...almost ready for him now Oh yeah...r/c/l didnt work. Dont have the card either to recode unfortunately ![]() Wishes for more power...
So a genuine item arrived today...all be it, only one, they sending another, their fault. Mist jets...third times a charm?
Anton said get the one that say "fiat" and sure enough I did and they were sealed in a genuine fiat/lancia packet. But fitted to right side...note the spray difference. Also rebodged the bodged exhaust. Now has a center box and a center box as a back box. Now doesnt vibrate or look like it will go puff in orange dust And a money shot... Little low at back due to boot of tools. Got a aux belt to refit, tmic, clocks back in as cannot seem to get rpm going... Then its wait for owner to collect...if I have a moment i may do a diy quickshift and gut the cat Wishes for more power...
29-04-2016, 09:11 PM
Why a TMIC over FMIC Piggy? cost?
Ive got those Fiat washer jets, really good!
29-04-2016, 09:13 PM
(29-04-2016, 09:11 PM)MY95 Wrote: Why a TMIC over FMIC Piggy? cost? Coz it has a tmic. And i dont have fmic ![]() The lad is guna make his own mani adapter...later mod Wishes for more power...
29-04-2016, 09:20 PM
Fair dos, crack on
29-04-2016, 09:27 PM
We over £250. Think at about £292.
But he said max £300. So all good. I've got no more time tbh. Need to get on with FCS prep Wishes for more power...
29-04-2016, 09:49 PM
Thought you might have been over the budget by now, done quite a bit for that budget though!
30-04-2016, 12:20 PM
Good work piggy lol looking well
30-04-2016, 04:22 PM
So had go ahead to finally black mask front lights. That and the cat being gutted and quick wash and my work here will be done...
Till we (I) build a rather epic ultimate onthecheap reliable veg burning engine and we fmic that. Wishes for more power...
02-05-2016, 02:19 PM
Its raining, so Im fighting silicone with oven aid Wishes for more power...
03-05-2016, 03:55 PM
Done.
All needs a clean n polish naturally...but hey ho. Just the cat removal and pump the junk out the tank and put some less black gunge in! Wishes for more power...
03-05-2016, 04:04 PM
Top work piggy its amazing what you can do on these without spending fortunes
Also laquered the black on the rear lights...once its fully cured I'll flat it and polish then should blend in with the glass a little better
(03-05-2016, 04:04 PM)tim 306td Wrote: Top work piggy its amazing what you can do on these without spending fortunes Aye... Doing the lights inc paint, laquer and some silicone cost about £6 as didnt use more than half a can of black, quick coat of laquer and some cheap silicone. Wishes for more power...
03-05-2016, 05:04 PM
MOT fail covering the reflectors
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
Oh yeah...taken chance to renew any bad, not blown, bulbs (lamps) for future proofing if you will.
(03-05-2016, 05:04 PM)cully Wrote: MOT fail covering the reflectors Ah but they aint the reflectors ![]() ...but thankyou for positive and encouraging constructive criticism ![]() Wishes for more power...
05-05-2016, 03:25 PM
Flushed the fuel system..pumped it dry and then added 5 litres of petrol...pumped dry...
Then added 20litres of white derv and had the return draining from pump till it came out clear. Also...home brew quickshift.reduced throw by 20mm and it cost... £0.00. Just a piece of metal tube I got for free at metal merchants, big of grinder and welding. Win Wishes for more power...
05-05-2016, 04:09 PM
That's the yearly tax for this cost?
the paint over the rear lights isn't for me..
05-05-2016, 04:30 PM
I don't see the point in changing some working bulbs that will blow at some point for some more working bulbs that will blow at some point.
![]() Surprising what you can do on that budget though. ![]() (05-05-2016, 04:09 PM)tigerstyle Wrote: That's the yearly tax for this cost? Not sure I understand the question? (05-05-2016, 04:30 PM)Toms306 Wrote: I don't see the point in changing some working bulbs that will blow at some point for some more working bulbs that will blow at some point. Picture doesn't show it...but the couple I replaced were going quite black...ready to blow Wishes for more power...
05-05-2016, 04:50 PM
He meant 'whats' the yearly tax. £145 a year if it was a hdi I assume.
Was a dw8... So full wack I think
Just checked...£185 a year Wishes for more power...
05-05-2016, 05:03 PM
Lol, wonder who decided they didn't want power, economy or cheap tax when that was new then!
