Wish I hadnt broken me foot now
Cracking wet lap time that cully...
You need a shift light though
Cully's Bianca 6 R150 YVM
![]() Cracking wet lap time that cully... You need a shift light though
22-02-2016, 10:57 AM
Hmm tuition on track in your own car. Seems like nothing but a good thing to me may have to try that myself. Good to see you're having fun with it man. Everyone spins on track once in a while as well. It happens.
22-02-2016, 11:24 AM
what has my trackday taught me!
Fast exotic cars arnt always fast, expensive cars look nice but people are scared to drive them, your not there to race anyone, track etiquette a std car with good tyres and small suspension tweaks can work well Rain levels the playing field, dont buy a caterham/7/westfield......one of my all-time wants has been squashed track tuition is not just for beginners .....highly recommend it! if a race circuit offers garages take one, you can have a blast with a £500 car built in a shed what has the day cost me... £170 trackday entry, £30 tuition, £110 fuel roughly 100ltrs, £140 tyres x4, these will go again £100 front disc/pads these will go again, £30 food costs, £50 oil change, I did around 170 road miles and 150 track miles to the fuel i probably have 1/4 of a tank left I had a very good day i would highly recommend it to anyone but please make sure your car is up to the track miles as they are hard on the car anyway im off to look at my next track day
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
22-02-2016, 11:38 AM
£600 for a day out?
![]() As long as you enjoy it though I guess its worth it.
23-02-2016, 04:54 PM
took the wife to the zoo for here birthday today to see her cousins
parked the car up and walked away with the std turn and take a picture pose................. she really looks a peach on std rims and std splitter, gone is the battered old gooner one ![]() i seem to have a list of things that need doing since combe 1. remove competition discs and pads they are a little un nurving on the road and they squeal when cold 2. refit the 16" wheels 3. replace the door loom drivers side as some wires have broken over the weeked 4. oil change closer to FCS with something better than the castrol Edge https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
24-02-2016, 04:37 PM
decided today to tackle one of the items on the list!
the dreaded Drivers door loom Ive had some new looms in the garage ive been saving for this as i knew id be doing it again so it started removed door to release the loom something was different to the last one i did i couldnt release the loom on the inside of the car so i wouldnt be able to pull the slack back into the cabin never mind there is a big enough space in the A pillar to eat it ![]() after a few hours of cutting testing soldering and sleeving all was done i found the copper loom wires on the car quite corroded, black copper is hard to solder, you cant unless you clean it up, I used a more aggressive flux ; I used plumbers flux the same stuff they use for soldering copper pipes i taped the loom up and fed it into the A pillar and refitted the grommet, refitted the door and tested before i had no heated mirrors or rear screen as the fuse kept melting but now i have it all working including electric window again ![]() quick check to see if the fuse was running hot but no ....... https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
25-02-2016, 10:48 AM
better than castrol edge? i thought that stuff was meant to be decent? or is it all just marketing?
25-02-2016, 12:04 PM
(25-02-2016, 10:48 AM)Eeyore Wrote: better than castrol edge? i thought that stuff was meant to be decent? or is it all just marketing? oh Castrol 5-40 a lot better than the Total 7000 10-40 i was using but on track watching the gauges you can realise when the oil is working hard and what happens to it at rpm vs psi vs temp i will be looking for somthing like 5-50 or 10-60 https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
25-02-2016, 06:43 PM
i use mobil 10w/60 on mine wont use anything else, expensive but worth it imo and it comes in 5l! perfect for a 6 lump with a 16 row rad
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
03-03-2016, 04:05 PM
changed my disc and pads back to my std set well tryed to......
i stripped the carrier bolt thread on the hub......bugger so an hour job turned into all afternoon in changing the hub i also managed to drop the drive shaft out the box and loose some gearbox oil, Double bugger! lucky i kept the hub set off the 6 i broke all back together now https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
03-03-2016, 04:28 PM
Gotta love having our own spare parts counter
06-04-2016, 04:36 PM
I will just leave this here
12-04-2016, 07:49 PM
this seems to be a familiar site on my drive
taken car off the road for some work! ![]() started to strip stuff off to gain access to the diff casing, managed to get far enough to release the diff, tomorrow i should be able to release the gearbox mount and lower/swing the gearbox for enough clearance so i can remove the diff completely https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
13-04-2016, 06:47 AM
Would've been easier just to remove the whole gearbox wouldn't it? Although I guess it's not so bad once the subframes dropped etc
13-04-2016, 08:36 AM
I thought you werent fitting it and were going to sell it!
13-04-2016, 08:07 PM
(13-04-2016, 08:36 AM)Eeyore Wrote: I thought you werent fitting it and were going to sell it! i will sell you this one ![]() as you can see i have got the DIFF out without removing the subframe, ive got a rather large lump on the side of my head where the diff cracked me one as i released it need to get some crown wheel bolts as one has damaged threads i will also get some gearbox oil while im ordering from peugeot crown wheel bolts part number 9800266980 £1.72 each https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
14-04-2016, 07:35 AM
14-04-2016, 09:17 AM
8x dif bolts,gearbox oil and diff to spreedo drive oil seal ordered should be in my local peugeot just after dinner today
gear oil is £7.50 +vat a liter speedo seal 264512 is 76p+vat bolts are 9800266980 £1.72 each
14-04-2016, 06:37 PM
couldn't get 8 bolts so have used 6 new and 2 used bolts,
have spaced the old bolts opposite each other so to keep the balance, the new bolts had thread lock blue already on the threads, so I have used thread lock on the used bolts, to which all were torqued up to 65Nm I was going to attempt to fit it tonight but Que the rain....... ![]() https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
14-04-2016, 09:05 PM
15-04-2016, 05:53 AM
(14-04-2016, 09:05 PM)Eeyore Wrote:(14-04-2016, 06:47 PM)Matt Wrote: Super shiney I love it!! Ok Ok i get it now Its not a bad thing Sam to end up Behind a Rover :p your probably right though in being slow as I will need to learn to power on exiting the corners earlyer, not like now feathering the power due to under-steer https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
15-04-2016, 04:53 PM
learning to drive it all again will be fun!!
I'm pretty jealous at how this project is turning out! ![]() TEAM CONROD SHITTING RALLYE!
15-04-2016, 05:17 PM
remember its still a standard engine, nothing trick other than light flywheel and a few suspension mods
15-04-2016, 10:49 PM
Yeah but it is clean asf! Something tells me the engine won't stay standard for long
16-04-2016, 07:26 AM
Any luck getting the diff back in?
Takes a little getting used to, hitting standing water at speed is an interesting experience. |
| cully's XU10J4RS | cully | 11 | 10,365 |
30-06-2016, 12:53 PM Last Post: welshpug |
| Cully's Electric car ..T project | cully | 144 | 98,881 |
16-04-2016, 04:14 PM Last Post: cully |
