xud aircon delete
want to remove the aircon pump. does anyone know the belt number i would need?
its a phase 2 xud.
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
Stick your reg in on carparts4less
(02-11-2015, 06:04 PM)Paul_13 Wrote: Stick your reg in on carparts4less
what good will that do? lol
Then change the options on the side to suit your needs...
I've just done it and it comes up with a non AC belt when I change the options
(02-11-2015, 06:34 PM)Paul_13 Wrote: Then change the options on the side to suit your needs...
a "non A/C" belt will not the be the same as a A/C setup with the A/C removed. It is a different length.
Slightly unhelpful post to the OP I know...
but at least he won't go and order the wrong one!
Ask nathan he just done an ac delete.
I do apologise, you're right piggy.
Sorry been a long day without a lot of sleep
(02-11-2015, 05:57 PM)tysonbully2k12 Wrote: want to remove the aircon pump. does anyone know the belt number i would need?
its a phase 2 xud.
The belt I used was 1153 it fits but doesn't allow me to use the this tensioner, it gives a slight squeak when revved from cold but is quiet after 20 seconds or so.
