Cully's Bianca 6 R150 YVM
f*cking hell mate, that could of been nasty. I'm always really worried about dropping my grinder.
Dude your lucky. My grinder slipped on me last week and exploded the cutting disc inchs from my face. I got the tinyest of scratch's on my arm. Yet when i accidentally tapped a disc with my hand. Blood everywhere
the rustiness has gone looks a lot better!
I am not gona do the whole bay just the chassis legs and the corner sections where water pools
ironicly i need a part that i have sold off the scrapper which is not in stock at Peugeot and is on back order
my local peugeot was good enough to do a dealer search and found one in the country at Scarborough
so a phone call later i bought it and they are sending it by post
item i wanted was the gear linkage boomerang with the ball mine the ball was cracked and loose
[Image: 20150811_160436.jpg]
[Image: 20150811_160442.jpg][Image: 20150811_160459.jpg]
GTI6 Info
She's looking good mate.
Looking sweet ThumbsUp
Very nice, must be a good feeling to know it's good to last.
[Image: mcetg0.png]
some parcels have turned up today
Genuine exhaust fitting kit Part No 1798-75
genuine Gear link control return Part No 2449-71
needed the control link as the ball on mine fell off with a tug
[Image: 20150812_191233.jpg]
I think i have found why the linkages rattle too....
the brass bushes in the control link were worn and there was slack in the pivit point with the new one all the slack has gone
question for you....Do I grease the ball in the tube???
the tube currently looks dry of grease
[Image: 20150812_190825.jpg]
GTI6 Info
I've always greased old ones, don't think they were greased new though, up to you I guess!
Didn't grease mine when I changed it on the 6 and never had an issue with it
parts for my oil pressure early warning have turned up
oil pressure gauge an adjustable pressure switch with a remote adaptor so I can utilise the second block oil way tapping
[Image: 20150813_094615.jpg]
GTI6 Info
clutch cables are easy to change with the engine out Tongue
GTI6 Info
with the new engine i will be fitting an oil pressure gauge and an early warning light set for around 20psi not the std 5 psi which warns when its too late
so ive bought a pressure gauge and a seperate pressure switch which i will be building into a two pod gauge holder
oil light will have a volt meter in the same pod custom pod
first mock up
[Image: 20150817_203156.jpg]
anyway ive just seen the post for expo so thought it a good goal for the new engine Smile
so this has happened in the last hour!
[Image: 20150818_080646.jpg]
[Image: 20150818_081802.jpg]
[Image: 20150818_082709.jpg]
its a little early to celebrate but its on its mounts Smile
GTI6 Info
Home made gortex PTFE butterfly gasket
[Image: 20150822_160756.jpg]
slurp anyone home!
[Image: 20150822_161023.jpg]
slowly getting there unfortunately thunder lightning and rain stopped play
[Image: 20150822_164717.jpg]
GTI6 Info
Clean engine and bay transforms a car. Looking great so far Smile
Good work pal!
well today was the big day......
I got on far enough to put fluids in and so i was itching to start it
first off i removed the fuel relay and turned over the engine till i had oil pressure
just to give the engine a fighting chance even though it was built up with assembly lube
anyway fitted the fuel relay primed the system a couple of times checked for feul leaks
then turned it over....
the thing only went and started first turn Big Grin
and i even forgot to plug in the cam sensor Doh
ignor the rattly old diesel i jump started her from
GTI6 Info
Yaah. Well done mate. Smile
Ooh shiny Big Grin
One step forward Two steps back!
started the car again today to get some more smiles
only to find an oil leak from somewhere behind the crank pulley Sad
[Image: 20150829_135519.jpg]
so knowing this is bad i tore it down before it had chance to contaminate any of the belts
so off with the covers nothing ovious now the pulley nothing so cambelt and lower pulley had to come off Sad
i really didnt want to do this but it had to be done so now ive removed cambelt and lower cam pulley
BASTARD! i damaged the lower seal fitting it Sad
[Image: 20150829_141256.jpg]
[Image: 20150829_141927.jpg]
I will give a brief how too remove Fuggered seal Wink
locate buggered seal
[Image: 20150829_141633.jpg]
drill small pilot hole in seal outer case
[Image: 20150829_141728.jpg]
screw in wood screw or self tapper to jack the seal out
[Image: 20150829_141852.jpg]
remove seal with screw attached
[Image: 20150829_141908.jpg]
clean surfaces and fit new seal carefully not trying to wreck it this time Tongue
[Image: 20150829_160015.jpg]
and thanks go's to me for making an awesome timing pin set, it worked a treat in the car too as wall as when I built the engine on a stand Smile
[Image: 20150829_173154.jpg]
GTI6 Info
Yeh! it moves under its own steam....
[Image: 20150830_172025.jpg]
temporary fitted oil pressure gauge till my pod turns up
[Image: 20150830_172047.jpg]
fitting the lights and bumper assembly
[Image: 20150830_175554.jpg]
clean bay Smile
[Image: 20150830_181050.jpg]
oil leak fixed cambelt reinstalled no tapping here Wink
engine sounds like it wants to rev quick with the lightened fly n pulley fitted
Smile
GTI6 Info
Nice. For some reason this motor is only one of the few petrol ones i follow on here. No idea why. Good to see the motors properly driving though. Smile
Last few bits were put on earlier ive got fed up with the plastic snap rivets on the front grill so ive replaced them with Rivnuts so now I can unbolt it easier Smile
[Image: 20150831_104635.jpg]
finished off with a wash and quick polish ready for tomorrow Being Taxed and out on the road.
first trip will be to Peugeot to get some Hockystick clips Wink
[Image: 20150831_134331.jpg]
I have not connected the oil cooler although it is fitted,
reason being it is empty and clean of oil,
I don't want to be running my running in oil through the cooler as I wont be able to drain it fully,
once ive done 3-400 miles running in, i will be putting better quality oil in it with the cooler
GTI6 Info
Is it just the video or is there a whine!?
Good effort though pal, looks ace ThumbsUp
(31-08-2015, 03:47 PM)Piggy Wrote: Is it just the video or is there a whine!?
all new belts maybe?
GTI6 Info
oof, just listened, belt too tight!
ok if the cambelt is too tight how to gauge tightness is correct without a gauge?
GTI6 Info
(31-08-2015, 04:10 PM)cully Wrote: ok if the cambelt is too tight how to gauge tightness is correct without a gauge?
Experience :p
On the longest run, the belt should twist no more than 90 degrees
its at 45 degrees now ?
GTI6 Info
(31-08-2015, 04:17 PM)cully Wrote: its at 45 degrees now ?
Yeah, that's way too tight. Slacken it off until you can twist it to 90 degrees.
Ah yeah thats the whine!
As Niall said, twist 90 degrees at the middle point of the longest length between pulleys.
Then do a couple rotations back to timing marks and check again Smile
  cully's XU10J4RS cully 11 10,227 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 98,122 16-04-2016, 04:14 PM
Last Post: cully
