09-08-2015, 12:50 PM
1920ag iirc, haven't got the facilities to check as i'm on holiday.
Paul's estate mk2 - air intake on
09-08-2015, 01:26 PM
Cheers bud
That's the code for the MAF sensor
09-08-2015, 05:47 PM
1920GW
09-08-2015, 05:49 PM
fuel pressure sensor from a 1.6 HDI (part number 1920GW)
09-08-2015, 05:50 PM
Found it
Any body know how much they are from pug?
09-08-2015, 05:56 PM
Listed as £76.94 inc VAT on Servicebox
09-08-2015, 05:59 PM
Ouch
Hoping it would be cheaper than that. I'm guessing looking at pictures they're located on the back of the engine in a bastard position on the 1.6 hdi
09-08-2015, 06:09 PM
genuine one here on ebay from a dealer at £60.
http://www.ebay.co.uk/itm/GENUINE-CITROE...3aaf671bf7
09-08-2015, 06:43 PM
Brilliant cheers!
10-08-2015, 12:57 PM
Damn, so close lol, sorry. Glad you found a cheaper one, think i paid nearly £90 a couple of years ago. :S
10-08-2015, 05:55 PM
No real need for the 1800 bar sensor, 1500 is well enough for 200 HP and all you will achieve is wear on the HP pump and injectors
10-08-2015, 06:44 PM
But I've heard different opinions saying you'll increase duration times and start melting pistons if you don't use the 1800 bar sensor
12-08-2015, 02:21 AM
There is time to get in enough fuel at 1500 bar with a good pump, 1800 puts alot of strain on the injection system and generates alot of heat. I think like the 6 bar oil spring idea it was thought good at first but was found to be a bad idea overall.
12-08-2015, 10:55 AM
I wouldn't like to request the CR system to run at 1500bar with a sensor that can only read up to 1500bar - the control system is going to have serious problems if you're attempting to run 1500bar with a 1500bar sensor and you get any overpressure - it cannot control it. The 1800bar sensor doesn't mean you MUST run 1800bar pressure - it just gives you the overhead, sure you drop resolution, but IMHO it's not a gigantic issue.
IMHO 1650bar is the absolute max the CP1S pump should be running, otherwise, yes, heating of the fuel will be a real issue as will wearing the crap out the pump.
12-08-2015, 12:31 PM
guess the DV6 runs at a higher pressure if its from one of them ?
12-08-2015, 12:58 PM
The 1.6 runs a higher max pressure, but it uses a Gen2 CR system which uses the CP1H pump which is designed for up to 1600bar operation, hence requiring the 1800bar sensor, it uses low-pressure side regulation and from what I've seen is closer in design to the CP3 series pumps, the entire system is designed to support 1600bar operation - the Gen1 system will just about do 1600bar, but you have to be prepared for a shorter pump life and increased fuel heating.
29-08-2015, 04:18 PM
Well she has another years ticket on it!
Mot man was lovely and lenient Gone for a hdi tuning map and 1800 bar sensor, I had a map tweak without the sensor and it's not driving right and smoking like crazy Alternator has been playing up as well, the light has been coming on when on idle and goes when revved. Looks like a delightful job to change. I'm going to get rid of the AC pump when I do it
05-09-2015, 04:57 PM
Just about to load up the hdi tuning map
05-09-2015, 09:25 PM
And bloody impressed with the results!
05-09-2015, 10:04 PM
Sounds good, any photos or videos of how well it goes since the tweak?
06-09-2015, 07:18 AM
I'll get one in a bit.
Talking the AC pump off this morning and replacing the belt ready for the alternator change
06-09-2015, 04:35 PM
06-09-2015, 05:37 PM
So how does it go with the new map?
06-09-2015, 05:38 PM
Much faster and hardly smokes at all
06-09-2015, 07:12 PM
Aircon pump etc weigh a fair chunk? Feel any quicker after removing it?
06-09-2015, 07:37 PM
Hope that this is the end to it cutting out , used to drive me insane when mine did it !
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
06-09-2015, 07:49 PM
(This post was last modified: 06-09-2015, 07:50 PM by Jonny81191.)
06-09-2015, 07:55 PM
Glad this is finally sorted!
Re AC pump, it's surprisingly heavy (around 5kg at a guess) but not noticeable after removal. Makes oil changes easier though.
06-09-2015, 09:04 PM
Ah sweet Tom, not worth doing as an odd job then. Bet it does make them easier, know that from experience of the thing being a bit in the way
30-09-2015, 06:22 PM
Alternator is starting to worry me, need to replace it when I get back asap.
Bit worried it's not going to get me back from Cornwall. Light keeps coming on at low revs, goes when it's revved above 2-3k. It's doing cracking mpg! Interested to see what it does |
