Paul's estate mk2 - air intake on
#91
Where I park I have to bump up into a kerb so lowering the front isn't an option. The rear is rubbing like crazy as the wheels are wider
Fitting the solid mounts as well.
Going to attempt to raise it now
#92
Raised it 35mm on the rear, now it's level.
Fitted the solid mounts as well. The nearside bar was a twat to get out, the other side was fine.
Fixed a few problems I came across which took a while
Was going to reseal the exhaust and refit it but I ran out of time
#93
[Image: 20150510_202307_zpspbby17bi_edit_1431285...zm3dcr.jpg]
Much better
[Image: IMG-20150510-WA0010_zpsjnhvfotx.jpeg]
Home brew torsion bar removal tool
#94
How easy did the torsion bars come out using that method?
#95
Bit of tapping with a hammer and a bit of force it came out
#96
Very happy with how the car is performing at the moment even with the clutch slipping as bad as it is.
Sacked off the hid's and put some night breaker plus in
Noticed the turbo spiking at 21psi which I may need to sort out
Handles well now I've got 4 tyres the same size on!
Re-sealed the exhaust.
Just need to do tracking next.
Jobs to do -
tracking
top mount bearings
wishbone bushes
short shift
clutch
Maybe stick some 21mm bars in and hybrid ARB
R70 pump and map tweak to around 165bhp
#97
That was a great read great pictures too! (I'm in the process of 'studying' for college exams) Once I get these exams out of the way, I'll be doing something similar with my 3dr HDi. Car is looking well!
#98
Cheers, glad you enjoyed reading it
#99
(04-05-2015, 12:59 PM)Paul_13 Wrote: [Image: 20150504_130634_zps56rme9am.jpg]
Would explain the non working hand brake and seized rear brakes
My hammer!!!!@ looking good paul
306 Rallye giving people a surprise because they think shes a 1.6 ;-) Silly people
I really need to return that to you lol
Did the the tracking again, amazes me how long it takes for the suspension to settle back in after jacking it up.
It was still toe out even though I thought I let it bed back in properly
Stop fannying around and replace the clutch! :p
Ha, yep needs doing!
This weekends job possibly
Worrying me as it took you soo long to do yours.
You stop fannying around and give it MOAR POWAAA
Clutch changed today, hdi flywheel has been replaced with a gti 6 flywheel and I used a dturbo clutch
All in all went well, cable wasn't too much hassle. I don't know what you old ladies moan about.
Had the box off in 1.5 hours, box went back on easily.
The cable without the auto adjuster works a treat, the clutch pedal is feather light
[Image: IMG-20150530-WA0012_zpscrbtkfwc.jpeg]
[Image: 20150530_123111_zpsxr7exxse.jpg]
[Image: 20150530_123117_zps85f6dat1.jpg]
[Image: 20150530_123125_zpszt91ka7r.jpg]
[Image: 20150531_193818_zpshkjpebby.jpg]
Excuse the fog lights
Fitted the quick shift earlier, bit of a faff but it's done now.
2nd gear feels really odd. I read in nialls guide it can feel odd
Your project is brilliant mate, and a fantastic guide with the fmic setup, I wish I was brave enough to attempt it but I'm not, so I'll stick to a boring stage 1 lol
Cheers mate see you're from Reading, where abouts?
I live in Tilehurst West Reading
How's the new clutch holding up to the power ? Has it stayed just as light with the new cable setup ?
Yeah the way to get the clutch cable in easier is to remove the bit of the blowers that gets right in the way.
Fair few people from reading on here Smile
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
Been good soo far. Planting it in 5th it was slipping the tiniest amount but that seems to of stopped. Guess the clutch has bedded in
And yes removing the AC pipes made life 1000x easier, why Peugeot designed it like that is beyond me!
I thinking of organising a RR day once you get your car running mate
might be interested in that if its this side of Reading or even Swindon :p
Good good, really is a massive change makes you realise how heavy HDI clutch's are
Yeah I meant that plastic bit inside the car but yes would have struggled with those in the way
Would definitely be up for a reading meet, running or on the road as there's a fair difference !
(07-06-2015, 07:49 PM)welshpug Wrote: might be interested in that if its this side of Reading or even Swindon :p
Cool I'll make some enquiries
Got some Fog light blanks I need to stick on.
May get round to fitting the r70 pump some time soon and rail sensor
Only RR I know of in Reading is the old Clifford Cox place up near Rivermead. Not much parking space though.
Actually, I think there is one in Wokingham. I know where it is, but can't remember what it's called. Went there some years ago for a Dyno shootout (Arthur Daley Jag with a tweaked & blown Chevy V8 won).
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
http://www.subaru4you.co.uk/rolling/rollingroad.shtml
Had a problem where it was cutting out at 3k full throttle
Gave the fpr a good clean and it seems to of solved that, blasted some clutch and brake cleaner through the holes at the Base of the shaft
[Image: 20150704_104228_zpsqin5geqm.jpg]
Also gave it a service, found a brand new oil and oil filter lying around so banged them on, happy days. There's me dreading a trip to Halfords
Changed the fuel filter to a genuine pug item
Going to buy a k&n panel filter I think for this
Fitted some Fog light blanks, pics to follow
Can't for the life of me find where this second horn plug is in the inner wing!
I like the torsion bar puller. I'm busy knocking something similar up at work. Are you smacking the bar, beam or the bolt head (or all of them lol) with the hammer when the bolt is loaded up? Surprised that bolt hasn't snapped!
Trying to strip my xsara beam in the garage, slide hammer isn't touching it.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Good luck stripping a xsara beam, I've had to cut torsion bars out as they were that rusty
Users browsing this thread: 160 Guest(s)
