quickshift
quickshift
http://www.ebay.co.uk/itm/PEUGEOT-206-30...51a17ba541
is this an alright budget quickshift or a no go??
They're fine generally, just sometimes the brass fittings come loose so need gluing or bigger grub screws
a bit shit really, not very well executed, always come loose.
Detest mine Smile
P1 XSi track car
2.4 LWB T4
I think they would work much better if the gearstick was sleeved so it fits tighter in the spherical bearing.
WELD THE lady garden!
How exactly do you put the stick through the ball? Do you have to remove the knob and the plastic off the top?
plastic? just pull the knob off, cut the plastic ball away and slide the stick through the spherical joint with a collar each side, well not so much slide but dick in a shirtsleeve kinda thing.
i think he meant the plastic sleeve the knob sits on?
I drilled a couple dimples in the shaft for the grub screws to sit in (on the compbrake QS on my ax)
never seen that on a 306, only later 406's with cable shift.
my 306 has it, wierd white plastic sleeve with a ridge down either side (to stop the knob rotating on the shaft) does this just pull off like the knob? I didnt want to force it and shatter the damn thing
(16-06-2015, 03:46 PM)thododd Wrote: my 306 has it, wierd white plastic sleeve with a ridge down either side (to stop the knob rotating on the shaft) does this just pull off like the knob? I didnt want to force it and shatter the damn thing
They don't seem to come off, shattered when I tried anyway.
I welded the collars on mine either side if it helps Smile It was already fitted previously but was a bit poo, didn't hold up 5 mins on track.
(16-06-2015, 03:23 PM)welshpug Wrote: never seen that on a 306, only later 406's with cable shift.
I think he means for the lift reverse on a gti6.
I had to slice mine off and tiger seal it back on with a few cable ties.
The cheaper way for quickshift is to extend the length of gear stick around 2"
Shift feeling are better !
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
(17-06-2015, 09:50 AM)maxzy Wrote: The cheaper way for quickshift is to extend the length of gear stick around 2"
Drugs are not ok Big Grin
(16-06-2015, 12:18 PM)connorp Wrote: http://www.ebay.co.uk/itm/PEUGEOT-206-30...51a17ba541
I got a pug1off one a couple of years ago. Never skipped a beat. Seems solid and im sure it was cheap as.
(16-06-2015, 04:08 PM)Lwilliams Wrote: I welded the collars on mine either side if it helps Smile It was already fitted previously but was a bit poo, didn't hold up 5 mins on track.
mine are welded too lol
Just fitted this to the 306 HDi. Hasn't shortened the shift by a huge amount, but its noticeable. Also gives the change a very firm feel. Took 20 minutes to fit as it's a direct replacement.
Unsure if it will fit a Gti6. And definitely won't fit cars with cable gear linkage, suitable for mechanical type only.
http://m.ebay.co.uk/itm/DIRENZA-PEUGEOT-...0952534271
Resident cat lover
(17-06-2015, 11:51 PM)Pebbles167 Wrote: Just fitted this to the 306 HDi. Hasn't shortened the shift by a huge amount, but its noticeable. Also gives the change a very firm feel. Took 20 minutes to fit as it's a direct replacement.
I think this would fit a gti6, you just have to make the lift reverse attach somewhere.
  compbrake quickshift fitting / adjustment zx_volcane 5 3,507 10-03-2016, 02:34 PM
Last Post: Piggy
  quickshift gearbox type mossy1985 5 3,163 09-01-2015, 10:54 PM
Last Post: cully
