Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Hi all,
For this summer I am thinking of taking on the daunting task of repairing a 306 hdi air conditioning system. I want my car COOOLLLLDD haha. I have heard they are a right pain in the A** so I am just wondering if anyone has ever actually managed to get one working reliably using new better quality parts and a re-gas?
What do you guys all think?
Thanks, Jack
Threads: 581
195
Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
Did it work the next day when i had to drive 2 hours to fcs in said 30 degree weather? Did it f*ck.
Threads: 85
8
Car Model/Spec: E90 330i
Given 15 thank(s) in 15 post(s)
(14-05-2015, 09:22 PM)Niall Wrote: Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
What happened?
Threads: 186
6
Haha brilliant lol. I actually want to get to the bottom of what causes them to stop working tbf haha
Threads: 581
195
(14-05-2015, 09:24 PM)Iceman299 Wrote: (14-05-2015, 09:22 PM)Niall Wrote: Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
What happened?
Dont know. Ripped it out shortly after in favour of boost. I would imagine there was either another leak somewhere on a pipe or the seals had just dried up seeing as it had been empty for so long
Issue is, to repair it and keep it reliable, you need to replace the front pipes (the known original issue causing them all the fail), most seals and the receiver drier. It all adds up!
Threads: 15
2
Car Model/Spec: XSi
No. The end.
P1 XSi track car
2.4 LWB T4
Threads: 465
114
Car Model/Spec: Vauxhall
my estate had working air con when i sold it
i had it repaired under warentee when i bought it new front condenser and lower front pipe and a regas fixed it apparently
must admit it was nice and cold
Threads: 85
8
My 306 has always had working a/c.
One i had for a few weeks last year had new pipes etc repaired by the previous owner
Threads: 186
6
It does seem to sound like it's just a condenser and a set of front pipes so don't see why I wouldn't be able to do it tbf haha
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
15-05-2015, 05:59 AM
(This post was last modified: 15-05-2015, 06:00 AM by highwayman306.)
Condenser is situated right at the front of the car and gets peppered with stones from the road. Bad design really so it wouldn't be long before its fubard again I might ditch my ac and save some weight/fuel...as it uses fuel when it is working anyway and weighs a fair amount which adds to consumption when not in use/working...all in all:
expensive to repair and replace and uses more fuel...
Threads: 202
58
(15-05-2015, 05:03 AM)JTaylor2005 Wrote: It does seem to sound like it's just a condenser and a set of front pipes so don't see why I wouldn't be able to do it tbf haha
You'll need a receiver drier and I'd imagine the seals will need replacing too.
Are you actually taking on what's been said? As Niall has already explained the above to you.. Tell you what, just change the condenser and front pipes then you can come back and be really surprised when it doesn't work/leaks R134a refrigerant everywhere, which BTW will give you serious frost burn if it gets on your skin.
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
I got mine working with just a condenser, drier, and new seals, no front pipes needed, still works 12+months later.
All cheap enough through eBay.
Definitely worth fixing!
Threads: 386
87
Got mine working 5 years ago with just a regas.... Back then the phrase 'it only needs a regas' wasn't always bullshit... Worked for the remainder of my ownership as well (nearly a year!).
However these days I wouldn't expect it to be that easy lol.
Threads: 186
6
See it does seem to be hit and miss really. Some people can get it to work some not. Just really like my cold cars so maybe worth having a look into in the future. Maybe improve on it by putting stuff in the way of the rad so it doesn't get mashed again etc.
Threads: 386
87
Blocking the rad would reduce the cooling, defeating the object. It's not too bad a location on 306s, the fan infront does shield it a bit. On the Focus the AC rad is right at the front, fan at the back so gets battered by stones and shit.
Threads: 136
11
I had working AC before some **** crashed into the front of it
loved it having a cold car
Threads: 2
3
Car Model/Spec: HDI DTurbo
16-05-2015, 10:00 AM
(This post was last modified: 16-05-2015, 10:05 AM by Ican.)
I fixed mine link to thread. http://306oc.co.uk/forum/showthread.php?...#pid304190
Just to add its still working today without needing a regas so the repair was a good one.
Threads: 26
Given 1 thank(s) in 1 post(s)
I fixed mine. New front pipes, condenser, receiver/drier. But then the spring clip under the fuel pipe was broken, so used some cable ties and clips to hold together. Was working fine last time I saw my car. Sent it to get some interior refinished and for various reasons I've not seen it for a few months!
Threads: 102
18
Was just about to say MisterGTR had fixed his but he's here already!
Threads: 10
Car Model/Spec: Meridian 1.9TD
I fixed mine by putting a new condenser on when I first got the car 4 years ago and it's still cold.
Threads: 186
6
Okie dokie so it is possible. It may be worth just trying a regas first then and seeing how that goes. I have been told its probably not going to last long and by the sounds of it that's very true haha. You never know I might get lucky and it may last the summer. If not then I will investigate I suppose. Start with a leak test. Where does them? Just find a nearby garage that can do them do you reckon?
Also thats a great write up mark thanks for posting that.
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Any place that does a/c will do a test first
Threads: 2
3
16-05-2015, 03:24 PM
(This post was last modified: 16-05-2015, 03:34 PM by Ican.)
Threads: 8
16-05-2015, 07:32 PM
(This post was last modified: 16-05-2015, 07:34 PM by Pgtips.
Edit Reason: Additional info
(16-05-2015, 03:24 PM)Ican Wrote: Save a bit of money http://m.groupon.co.uk/deals/premium/ats...r/62021291
Wonder if they still charge if they find a leak
(Pressure check will take up to an hour; if a leak in the air conditioning system is detected, the recharge and treatment will not proceed)
Threads: 26
17-05-2015, 12:20 AM
(This post was last modified: 17-05-2015, 12:21 AM by MisterGTR.)
Go to kwikfit. They only charge if they can charge your AC. So first time I went after doing all the replacement work, they told me that they couldn't charge the system and actually pointed out the issue with the spring clip ie where the leak was. Which I bodged and got working.
Threads: 9
Car Model/Spec: 306 2.0 HDi D turbo
The A/C in my xsara works perfect, the 306 doesn't. That could be due to the missing A/C rad...
Do Peugeot still sell the parts or do I need to visit the scrappies?
Threads: 26
(19-05-2015, 02:24 PM)Will Wrote: The A/C in my xsara works perfect, the 306 doesn't. That could be due to the missing A/C rad...
Do Peugeot still sell the parts or do I need to visit the scrappies? I bought a Nissens one off eBay.
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Mine has just given up after a regas a few weeks ago (whole point of the regas was to find the leak, it's really small apparently).
Got a set of new front pipes, a new dryer and new condenser ready to go on. Pretty much why my FMIC hasn't been fitted yet. Want to sort this first. Got the Dryer and Condenser off Amazon of all places, under £100 for both and they're Valeo.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 11
Car Model/Spec: 306 HDI Stage 2
We're did you buy new front pipes from?
Threads: 91
2
(20-05-2015, 02:35 PM)Alan_M Wrote: Mine has just given up after a regas a few weeks ago (whole point of the regas was to find the leak, it's really small apparently).
Just got back from the garage, and whilst there is no sign of the dye, there is a lot of dampness in the corner of the condenser.
Next step is to replace condenser & dryer, and probably new front pipes too. The A/C was great when it worked, and sorely missed over the last few days. I plan on keeping the car for a good few years, so don't mind chucking a few quid at it to have the little luxuries working properly.
Big UP to CitroeMech in Wokingham, who re-gased the car and sent me on my way a few weeks ago, didn't charge me today for hunting down the leak.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
