Sack off your auto adjuster on your clutch cable (BE3 Pull type)
Been doing a bit of research and have made a little discovery.
This will only work on PULL type clutches eg:S16 GTI6 Dturbo . NOT HDI (as this uses a push type clutch)
As i'm converting my HDI to a pull type clutch and GTI6 flywheel this will work perfectly.
Now this is the cable I used (Citroen ZX 16v BE3 Pull type)
[Image: 20150416_132400_zpskjvmqqep.jpg]
There's differences in the bung which goes into the pedal box, also a slight difference in diameter on the plastic part:
Left = ZX cable
Right = 306 Dturbo
[Image: 20150416_131834_zpspt6cfxke.jpg]
Remove the bung on the ZX cable and slice it off
[Image: 20150416_132215_zpsfnnamj2y.jpg]
Remove the 306 bung by sliding it off, over the plastic clip. No need to cut it (ignore the hack saw blade.
[Image: 20150416_132219_zpsdesc5my7.jpg]
Slide the bung over the end of the ZX clutch cable, now this is where the slight difference in diameter causes a slight issue but i was going wrap a bit of insulation tape around the plastic part so the bung sits central. I cannot see this causing an issue. Or may finding a thin plastic sleeve to take up the gap.
[Image: 20150416_132335_zps6dw1jydv.jpg]
And voila! Finished item. A adjustable pull type cable for a BE3 box .
I'll be fitting in the next few weeks.
[Image: 20150416_132346_zpst6lxzfbk.jpg]
aha, I did wonder if the late ZX ever used the conventional 306 style pedal instead of the clip like the xantia and the 405 used.
Exact cable setup I used on the 206 XUD. Though I used a Xantia Cable.
Should be ideal for the 306 if your adjuster is playing up.
(16-04-2015, 02:04 PM)welshpug Wrote: aha, I did wonder if the late ZX ever used the conventional 306 style pedal instead of the clip like the xantia and the 405 used.
I did originally get the earlier version clutch cable which has the different pedal and the plastic clip which is prone to snapping
  Guide: How to re-cable Single cable Regulators. insomaniac45 5 4,449 06-09-2015, 08:47 PM
Last Post: Poodle
  How to fit a new clutch cable Niall 13 18,247 06-02-2014, 01:30 AM
Last Post: sweeney1987
