car feels skittish round corners? it never did befor an ideas guys ?
had track rod ends, suspension droplinks, driveshaft and wheel bearings done on the car, its fixxed my shakey gearstick, but its a lot more skittish round corners now tho any ideas guys ??
Has it been re tracked after track rod ends where fitted?
Yeh, but I think he tracked it shi*, it drives straight but my steering wheel isnt
That'll be the problem then, most likely any way.
I'd whip the wheel off and retorque the bottom ball joints for peace of mind (35nm) make sure he's put the right size in as well as they come in either 16mm or 18mm
Dont have a torque rench or I would, gonna get it re tracked and see how it goes
When ever suspension work has been done you really ought to have laser alignment done just in case, its worth the £15-20 alone to stop your tyres from getting killed.
Ino im gona get it done on tuesday, I hope it is just the tracking
Most half decent indie tyre fitting centres will do laser alignment and if somethings not right they will say.
Aircool is right, laser alignment is well worth the cash and like he said, most backstreet guys would have a look and tell you if there are any other problems. Avoid kwikshit as they charge a pretty penny, BUT, the do allow you to go back within 30 days for a free recheck/realign Wink
Yeh theres a place near me what does it, can lower ball joints be too tight
  Lowering 60mm all round Adam CD P1 11 6,550 18-01-2016, 11:29 PM
Last Post: Adam CD P1
  Clutch feels stiff! Moh 9 5,259 14-11-2013, 08:59 PM
Last Post: 306pc
  handling feels dodgy at front end davieboy-rfc-1690 7 4,537 03-11-2013, 09:32 PM
Last Post: titch
