Threads: 136
11
I've put it down to a slipping clutch. I had a load of weight in the car and it was slipping badly. Might of been the egr valve as letting by as well
When the clutch slips it throws up a fault code. I got a feeling it backs off the power.
Engine speed and vss speed unsynchronised
(08-03-2015, 08:22 PM)MY95 Wrote: You fitting a bigger turbo in the long run or staying with the standard one?
Standard one for the meanwhile, but who knows in the future
Threads: 136
11
Night and day difference with this on
Pulls better from lower down and feels happier up the Rev range.
I was looking at the old pipe that goes from the inlet to turbo and it goes down to near 1" at one point.
Just need to fabricate the back box now.
Threads: 82
27
Word of warning, that top rubber 406 pipe will probably need changing for a hard pipe in future or at least something underneath it to stop it rubbing. It'll be fine off, but when the engines running the pipe expands under boost and will rub on the thermostat housing. Eventually it'll wear though
Threads: 136
11
Ok thanks for the heads up. I think I've got enough spares to replace it now
Threads: 82
27
In fairness ours has been on for years and only just rubbing through, but don't really want a hole in the thermostat housing lol. Will be swapping to a hard pipe myself soon.
Threads: 136
11
Unplugged the MAF this morning as it was a bit temperamental on whether it wanted accelerate or not.
Goes better down low so a new MAF is needed
Threads: 49
Top work  nice use of pipe clamps too, you a pipe fitter?
Threads: 136
11
What makes you say that! Glad you didn't say plumber
Threads: 49
Just purely the use of that style of clamp and stud iron  perfect for the job though...
Threads: 136
11
A lot of people don't know what a pipe fitter is so hats off to you sir!
Threads: 49
(14-03-2015, 06:54 AM)Paul_13 Wrote: A lot of people don't know what a pipe fitter is so hats off to you sir!
No, hats off to you mate. Do a bit myself, and have worked with a coded pipefitter/fabricator. Very skilled lad, and obviously his welding is second to none.
Threads: 3
Car Model/Spec: HDi 90 meridian
Country:
looks a good install need to get a list and start collecting bits to get one on mine.... knew i should of bought a 110 not the 90 grrr lol
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Come on then, where did you get the I/C and pipes from?
On the clutch, what exactly do you need to convert to XUD one? Does the arm have to be from an XUD, or can I steal one from one of my many BE3/6 boxes?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 18
10
Use a GTi-6 flywheel, clutch arm and fork Alan which you should have in the garage - that's what I did on my 306 HDi.
(GTi-6, S16 and TD all share the same pull-type clutch setup)
Threads: 136
11
(18-03-2015, 02:43 PM)Alan_M Wrote: Come on then, where did you get the I/C and pipes from?
I've been meaning to do a list of the bits I've used.
I'll get round to it at some point.
Threads: 136
11
Don't forget to swap the clutch cable for a dturbo /6 item
Any reason why you cannot fit the I/C & pipework and run on a stage 1 map?
I ask, because I'm pulling the subframe off mine soon to fit a VTS rack, and the bumper to sort the A/C. I could fit the I/C etc at the same time.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 136
11
That's what I'm doing Alan, stage 1 with intercooler.
I've found it makes a fair difference
(21-03-2015, 02:23 PM)Paul_13 Wrote: That's what I'm doing Alan, stage 1 with intercooler.
I better get ordering then.....
D'you think there is enough room for the A/C and standard fans to stay? I see you've got rid of the A/C.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 136
11
You might get away with retaining the AC rad. But definitely not the fans
Threads: 136
11
Boosting nicely at 13-14psi
Next job manual boost controller
Threads: 541
124
WORST
EVERRRRRRRRR!!!!
[to be read in comic book guy voice]
Threads: 136
11
I know, I know...
JP I'll be in touch about the stage 2 map
Threads: 82
27
If you've got a KO3, I wouldn't bother with the MBC.. you can adjust it with a medium length 10mm (iirc?) spanner from below pretty easily.
Threads: 136
11
I'll have a look thanks but if it's the same turbo as Powerandtorque has, I don't think thats an option
Threads: 136
11
I understand there's 2 different types of turbos on hdi's. Is it the same difference between the t2 and kkk on a dturbo?
One has an actuator arm, the other built in?
Threads: 11
Car Model/Spec: 306 HDI Stage 2
Given 8 thank(s) in 8 post(s)
21-04-2015, 07:00 PM
(This post was last modified: 21-04-2015, 07:01 PM by shervo.)
You will have either a gt15 or k03.
Ko3 is two nuts both 10mm iirc
Gt15 cas a circlip and a thumb screw to adjust. Either way fitting a mbc is best because then you can adjust easily from the top.
Threads: 136
11
When you say 2 nuts? As in a kkk turbo on a dturbo?
Sorry I'm struggling to get my head around it
Threads: 136
11
Like that?
Threads: 11
