manual boost controller and egr blank plate fitting, please help
Could somone please help, how to fit an egr blank plate (slot in type) what part need blanking, how is the best way to fit an mbc as there isnt much room to get to the turbo from under neith the car
Have a look in the guide section mate, this has been very well covered.
Im not gonna lie i cant find anything, thats why ive made a post haha
I have to admit I struggle to find stuff in the guides sometimes. It has that annoying search length thing meaning you cant search for "egr" haha
look at steves at hdi tuning excellent guide on his downloads page
Guide: How to fit a ball and spring mechanical boost controller
A mechanical boost controller can be used when you want to increase the boost pressure on your HDI
90 to go with an intercooler and a stage 2 remap.
You will also need to fit a boost gauge to monitor the boost pressure is at a safe level. The best place to
take a boost pressure reading is from the aluminium inlet elbow at the intake manifold. This will give
true manifold pressure. Do not fit the boost gauge to the compressor housing.
It’s important you don’t fit a mechanical boost controller on the 110 or 136 models as these use
electronic turbo control.
How does a mechanical boost controller work:
A mechanical boost controller reduces the pressure being sent to the waste gate actuator from the
compressor housing. This means that the waste gate will not open at its factory set values; instead it will
open at a higher pressure and regulate boost pressure still. This has a similar effect to lengthening the
waste gate actuator arm; however it’s easily adjustable and maintains full movement of the actuator.
Parts you will need:
1. Roughly 1.5 meters 4mm ID silicone hose.
2. 2 x 4mm straight hose joins
3. 6 x jubilee clips to suit OD of silicone hose used.
4. Mechanical boost controller (don’t use the cheapest bleed valve MBCs, they don’t work well.
Typically the brass ball and spring units give good results.
How to fit a ball and spring boost controller:
1. Remove the right side wheel. Be sure to use axle stands to support your car.
2. Remove the wheel arch lining. You should now be able to just about see the turbo charger.
3. Cut the pipe between the compressor housing and waste gate actuator as shown below. On
some models the actuator will have a plastic pipe, be very careful not to snap this otherwise you
will need to remove the entire turbo to repair it.
4. Using the straight 4mm connectors, join half of the silicone hose to each pipe, run this up to the
top of your engine bay. Use the jubilee clips to tighten.
5. Connect both hoses to the mechanical boost controller. It’s important you get the pipes the
correct way around. The hose joint to the actuator (right) should go to the outlet of the MBC,
the hose joint to the compressor housing (left) should go to the inlet of the MBC.
6. Screw the boost controller all the way out to start with. Test your car to ensure the boost
pressure is still near to 16 psi. If so you have fitted it correctly.
7. Gradually screw in the controller until you reach 20 to 21 psi maximum boost on your boost
gauge.
How to fit a bleed valve:
We don’t recommend fitting a bleed valve, however if you’ve already bought one this diagram below
will show you how to fit it.
First page of the guide section, took about 10 seconds of scrolling to find: http://306oc.co.uk/forum/showthread.php?tid=13047
Just saying. Wink
Ooooo you are good lads :-)
  Boost controller GFB G-FORCE II loli_04 6 5,134 18-03-2017, 11:03 AM
Last Post: loli_04
  Recommendations for boost gauge and fitting kit 306rhys 6 4,580 30-07-2015, 07:56 AM
Last Post: Poodle
  electronic boost controller ??? Donkeybubles 5 3,673 16-07-2015, 03:41 PM
Last Post: JTaylor2005
