21-03-2012, 07:07 PM
Fair enough :-)
Stage 3 XUD project
22-03-2012, 12:54 AM
Td04 is on seems to boost up nice, still got fuel way down atm, but it dosent die at 3500 anymore, so must of been wastegate/actuator issue on the t25..
22-03-2012, 08:50 AM
![]() ![]() only pics i took really, might not look pritty but its down the back out of sight and it works
22-03-2012, 03:51 PM
what the hell did u use to put elbow on
![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
22-03-2012, 04:07 PM
need to get my elbow done so i can get td04 on but cant get elbow off t2 wont bloody move aha
22-03-2012, 04:13 PM
Glad you got it sorted mate looks good
Current cars Subaru Impreza 2.0d - Daily 306 1.8 - track whore soon to be GTI6
22-03-2012, 08:19 PM
studturbo Wrote:need to get my elbow done so i can get td04 on but cant get elbow off t2 wont bloody move ahayou can swap a engine but you cant remove a few boltsn :roll:. told you get a impact driver and wd40
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
11-04-2012, 05:47 PM
Got some new catch tank hoses today along with an inline filter, also jazzed up the power steering pipe with the spare catch tank hose..
11-04-2012, 05:55 PM
Have you added it in addition to the current filter?
11-04-2012, 05:57 PM
It drives exactly the same, and no the old filter and housing are nomore only the one under rear seat is left
11-04-2012, 06:22 PM
kingy Wrote:looking good padge. by the way your 2 clips missing off your grill. factory standard, no car has a grill intact..
Phaes 1 GTI 6 - Onyx Black
09-05-2012, 07:23 PM
So today went to jenks house, and he kindly rerouted my battery and mounted my oil cooler.
09-05-2012, 08:34 PM
Have you got fans on the oil cooler or something?
Even if you have, cant see it being very effective in there as the airs hot / its just gunna circulate the same hot air around and around.... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
09-05-2012, 09:02 PM
Was something that I had discussed with Kyle the way it's set should be enough room below to get a cold air feed up into I did also mention about possibly a fan too. But the cold air feed or fan is upto Kyle now
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
09-05-2012, 09:08 PM
Hm yeah but theres not gunna be naff all air flow there....the engine bay just turns into a big warm air space....all the hot air from the rad / engine just heats it up, like that install unless totally isolated is going to make no difference :S
So you relocated your battery at expanse of cable / battery box etc, and spend 100+ quid on an oil cooler, and fitted it where it wont make much / if any difference at all lol.... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
09-05-2012, 09:12 PM
Have you still got your stock cooler into the coolant system?.... cos having it there will overheat due to lack of airflow as soon as you push anything, no offence kyle but thats not very race spec
and anyone who looks at that will wonder why you've done it because it provides no advantages at all?
09-05-2012, 09:15 PM
because racecar
09-05-2012, 09:23 PM
because racecar ?
Yup that is completely and utterly pointless/has the opposite effect entirely!
09-05-2012, 09:24 PM
As Dave said, hope you have left the stock water cooler fitted, as the stock cooler does ALOT more than you might think, and theres no way on earth that is going to manage that, let alone offer a boost, so you will be cooking oil if you have bypassed the stock bit, which if you havent, also defeats the point lol...
Just get it mounted somewhere in air stream them ur money is doing its job, atm its just wasted... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]() |
| 306 Stage 2 HDi Progress/Project. | mcglynn | 139 | 117,572 |
31-12-2018, 02:09 AM Last Post: Allistairc123 |
| Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. | Matt-Rallye | 29 | 26,040 |
10-05-2017, 12:49 PM Last Post: Poodle |
PH1 genesis STDT sedan! Stage 2 soon be stage 3 GT20 | strictly_perv | 127 | 78,420 |
16-06-2014, 05:06 PM Last Post: MissTap_GTI6 |
