turbo oil feed
turbo oil feed
After my initial shakedown of my 205 after its rebuild everything is going smooth enough.
However my turbo oil feed on the turbo side(2 bolts into the turbo) has started to leak once the engine is warm.
I had this pipe off when the engine was out(t2 turbo) I dont want to nip it uptoo much in case the bolts snap
Do these gaskets go often? or is it a cause of manning up and tighten the bolts.
I was thinking of using some durco and new bolts along with the gasket
Two bolts is the oil return. Not the feed. I think anyway. If it is renew the gasket man.
(19-01-2015, 08:09 PM)bashbarnard Wrote: Two bolts is the oil return. Not the feed. I think anyway. If it is renew the gasket man.
what he said . . .Smile
Any links to these gaskets?
Thanks
Is that the return gasket inside the red box?
That's not it.
http://m.ebay.co.uk/itm/390633054393?nav=SEARCH
thanks for the link Smile
Could you pm me your number conor, I missed your message about the helper springs.
I'm in no hurry I plan to finish the car around march, so I can wait until your next order.
Thanks
  Twin turbo high pressure oil feed setup. 205dtub 17 8,778 23-02-2015, 07:47 PM
Last Post: 205dtub
  Turbo oil feed willJspears 7 5,404 30-12-2014, 07:12 PM
Last Post: Frosty
  turbo oil feed thread? ozonehostile 18 14,050 27-05-2013, 02:51 PM
Last Post: ozonehostile
