Galletto 1260
I have paid for my map but cant get galletto 1260 to work can it run on any newer windows
how did you read your map?
i suggest contacting your mapper for assistance if you read your map and cant write it
I cant get the cable to load on my laptop
I've used Galletto on Win8 with a 306 without issue, a lot of people do have problems though.
Sometimes the gallettos are a bit broken, first one I bought wouldn't connect properly so got a second one and it's all fine
[Image: mcetg0.png]
It sayn no matching hardware contacted seller to get new 1 sent
When reading file it says opening port impossible can any1 be of any help
You need to ensure it's installed correctly, and that it's listed as a com port in device manager
Could be incorrect driver, go to hdi tuning website and download the software on there (should be under downloads) Try going into device manager (click start type run in the search box and in the run box type "mmc devmgmt.msc" without the " included. Inside find the device and then right click then press update driver, navigate to the folder that you downloaded from hdi tuning and it may work once you've updated. Just an idea.
Team disASTOR? Itwasntme
Was faulty eobd wire the solders inside were al messed up new 1 sent out today i hope as iv went for jammapic map and what i hear the results even just stage 1 pretty impressive from standard
ive just installed a jammapic stg1+ map and im quite impressed even with a faulty MAF sensor Wink
Impressive changes between stages Smile after standard power it's such a big change Smile
Good good as im looking forward that wee bit extra
  galletto problem mattydturb 0 1,607 01-05-2015, 06:42 PM
Last Post: mattydturb
  Galletto 1260 Dougieboy1 1 1,983 07-11-2014, 01:02 PM
Last Post: Toms306
  Galletto 1260 Windows 7 lolsteve 15 10,052 05-03-2014, 02:24 PM
Last Post: Midnightclub
