Galletto 1260 Windows 7
So I've been trying to get the galletto to work with my 7 laptop today
First off plugging the galletto into the laptop caused it to search windows update and couldn't find anything resulting in a 'bum bum bum' noise when plugged in.
I tried to use the drivers supplied but couldn't get them to work because something .ini was missing
Uninstalling the device from device manager I tried a different usb port which resulting in windows update seeing it as a usb serial convertor and usb serial port (com 3) which installed and was happy, opened up the galletto 1260 software and clicked ecu data which said 'ok' then tried to read which took some time but came back with an error.
Any idea if the drivers that windows installed are suitable? or how to get it to work with windows 7 as the drivers in the cd and I got online are titled 'DRIVERS_EOBD2_2K_XP' which sounds like xp drivers and may be trying to use something that was in xp but isn't in 7 hence the error when installing?
[Image: mcetg0.png]
Have a search #piggy
But yeah Danny (midnightclub) helped someone with exactly this issue and he posted up the drivers somewhere Smile
I did search , people say it works with windows 7 but not how to make it work. the drivers are all for xp, i tried some other stuff i found online but no luck. so trying a xp partition
[Image: mcetg0.png]
I just installed the drivers and it worked. Undecided tom says it worked with win8 but it wouldn't work for me so I tried win7
(01-03-2014, 07:31 PM)kentiiboii Wrote: I just installed the drivers and it worked. Undecided tom says it worked with win8 but it wouldn't work for me so I tried win7
What do you mean just installed though because when i tried to install the supplied drivers I got this
http://306oc.co.uk/forum/attachment.php?thumbnail=13919
[Image: mcetg0.png]
Everytime I read the ecu data it comes up with different figures but a pattern, either sarr.. , lots of 000's or just a mess
Could this be a defective cable?
[Image: mcetg0.png]
I'd go with defective cable, try another one... They're so cheap these things it's a wonder they work at any time...
Don't try and install the drivers through that program, install them manually through task manager.. aka select the device, update drivers, 'i know the location', then select the folder with the drivers in, it should then pick up the tool and install it properly
Yea I managed to get xp on the laptop , had trouble because hp fiddled with the acpi.sys which prevented xp installing
Cable still didnt work, seller wants me to post it back to them for a refund so I'll now be £2.60 down Sad
[Image: mcetg0.png]
Unless they explicitly state that the buyer pays for return postage in the ad, then by eBay rules, they have to pay it.. Saved me a fair wad of cash on returns over the years
Returns policy
After receiving the item, cancel the purchase within
Return postage
14 days
Buyer pays return postage
The buyer is responsible for return postage costs.
Return policy details
1.For every item,we will provide 1 year warranty and the free technical service. 2.Each item will be checked and tested carefully by our QC before sent out.
3.14-day Money back & Replacement Service is provided after you received the item.
4.If there is any problem of the item, please contact us freely within 14 days after you receive the item. So i hope customers could be cooperation with us when we help you to solve your problems. Anyway we will try our best to provide the top-ranking service for you.
So it seems like I have to pay returns postage Sad at least there was a year warranty
[Image: mcetg0.png]
And it's definitely 100% installed correctly? So there's no hazard warning yellow triangle on any of the devices in device manager?
No yellow boxes on 7, there's a few on xp but thats stuff like floppy drivers, audio and power management
The usb serial port (com3) and usb serial converter are not yellow
[Image: mcetg0.png]
If there's no option to change the com port within the galletto software then go into the settings within device manager and change the com port to 1 instead of 3, then give it another shot. It's definitely installed correctly though
Tried com1 no luck still not giving back proper ecu data
[Image: mcetg0.png]
Sounds like the tool is fecked then i'm afraid mate
  galletto problem mattydturb 0 1,686 01-05-2015, 06:42 PM
Last Post: mattydturb
  Galletto 1260 Dougieboy1 12 5,653 14-11-2014, 06:29 PM
Last Post: Dougieboy1
  Galletto 1260 Dougieboy1 1 2,089 07-11-2014, 01:02 PM
Last Post: Toms306
