fuel solenoid
fuel solenoid
Hi pug boys.
Does anyone have a picture/guide on how to remove stop solenoid on hdi injector pump. Have tracked down my start probs to this, help appreciated.
Cheers
I'm pretty sure there isn't a stop solenoid on a common rail pump. Confused
There isnt only a sensor on it. Stop solinoids are for older diesels like xuds. Newer hdi stop injector pulses hence no fuel.
Rofl
I'm intrigued, what diagnostic process did you follow to come up with that?
ye there is no stop solenoid on the hdi pump just a regulator valve.
what problem are you having?
(17-10-2014, 05:45 PM)madmadmax Wrote: ye there is no stop solenoid on the hdi pump just a regulator valve.
Ok. Problem being it will not start after stopping say fuel fill up or shopping. I have to turn ignition on twice for it to start. It`s had a new fuel pump in the last three wks. A mechanic reckons it`s the fuel stop or solenoid, whichever is on the pump. Hopefully it will be resolved nxt week.
Has it had a new lift pump or hp pump? If it was the hp pump then i'd be looking at the lift pump. You want to get it on live diags really and see what's happening when it doesn't start, will give you a much better idea of what the problem is. But then a proper mechanic would have done that for you already rather than making bad guesses...
(18-10-2014, 06:07 AM)Poodle Wrote: Has it had a new lift pump or hp pump? If it was the hp pump then i'd be looking at the lift pump. You want to get it on live diags really and see what's happening when it doesn't start, will give you a much better idea of what the problem is. But then a proper mechanic would have done that for you already rather than making bad guesses...
Ok it was a new lift pump. The garage are going to do a diagnostic test, don`t know if they use pp2000 . It`s bloody annoying re start prob. Cheers for advice.
if it takes priming to get it started i would be looking for leak from some where rather than sensors.
As above, if priming twice helps then it follows that you've got an issue with the low pressure circuit, rather than anything on the hp pump. My first call would have been the lift pump too tbh, was it a new one that was fitted? Perhaps worth taking a look at the fuel relay and filter housing.
My fuel relay is failing.
The lift pump doesn't always prime first go.
(21-10-2014, 07:15 PM)Paul_13 Wrote: My fuel relay is failing.
All my relay`s have been changed and lift pump in tank. I still have this intermittent non start, it`s either the immobiliser or something electrical on the HP pump, you too?
  Stop solenoid Jukie88 11 3,537 20-12-2013, 01:28 PM
Last Post: Jukie88
