Roof lining
Hi everyone
Has any one removed a headlining and painted it
If so how did it go
Or what is people's opinions on this Huh
Just did mine as removed sunroof and replaced with a carbon fiber blank.
I went to use fabric dye but was a waste of time as didnt cover the bit I tested on very well so used rattle cans and it now look wicked
(22-08-2014, 02:59 PM)calibra306 Wrote: Just did mine as removed sunroof and replaced with a carbon fiber blank.
So painting works I've thought about it I re-dyed my rear seat and thought head liner wants doing but wasn't sure if it'd work
thanks Smile
Spray paint So it gets into the fibers. Heard people say it will go crusty but it come out fine.
I'll take it out this weekend and get some satin black on it see how it goes
Thanks again
Moved this to the correct section Smile
Dont paint it. They go horrendously crusty and horrible. If i was you, buy some material and some automotive spray glue and recover it. its really not that difficult and the finish is 10 times better
[attachment=18530]
Thats a small photo of mine done in fake suede.
Thanks it looks good was it hard to remove
Pull the door rubbers down, remove the interior light panel and sun visors, pop off the pillar trims. And drop it out.
Thanks that's this weekend sorted Wink
[Image: imagejpg1_zpse2d9894d.jpg]
What do you think to this? my car is Diablo red
Not a fan.of the red but I like the suede. Ive still got to get black trims on mine first though
Niall. When you mention it going crusty do ya know if thats after time it being sprayed and fitted or some peeps experiance of it doing it once its sprayed or during.
Glad I clicked on this as I now know how to remove the roof lining ready for sound deadening cheers for this thread
Thank for the advice I think I'm going for recovering option in a black leather look and painting the stereo surround and vent Diablo red
What ya gonna use mate? Cloud 9
Anybody got recommendations as to what material to use? Going to be doing this soonish, and wondering about how stretchy the material needs to be, i.e. would a bedsheet work?
[Image: sigcopy-1.jpg]
Calibra306 was that for me? Don't want to steal the thread but been looking at Silent coat give it a try as it's not overly chunky at 3mm
(22-08-2014, 09:35 PM)Kezzieboy Wrote: Anybody got recommendations as to what material to use? Going to be doing this soonish, and wondering about how stretchy the material needs to be, i.e. would a bedsheet work?
Bed sheet can be a bit thin, will work but wrinkles show easy so smooth it out well. Duvet covers are a good option, usually a little weightier material than a sheet, also good for getting a pattern or design if you want something different. Suede is a good call, black keeps it nice and simple, hides and wrinkles etc well.
Material with a bit of stretch will make it easier and neater, but its not required, you may find you end up with a few small wrinkles around the tight bends like the handle reccess and the sun visor recess if your material doesnt have any stretch.
My suggestions are, get yourself a nice big workspace, some decent high temp adhesive (Trimfix on ebay), lay it all out and start with the area above the frint seats, work your way back from there leaving the edges for last, spray both the roof lining and your material with the adhesive, dont need too much or it will soak through but a good covering on both, i usually do it in roughly a foot or two sections at a time, lift the material up, spray the section, lay it back down and smooth from the middle out. Once tge centre section of the roof is done go back and do all the edges, wrapping it over the edge and gluing it down to the back will stop the edges peeling. Then trim off any excess, give it a chance to dry, refit.
I have done about three or four of these trimfix is great stuff and worth using. Go to a local material shop and have a look around you want something nice and thick so the glue goes not come through when you stick it down. I actually have a 5 door one in the garage which I did with brown material if anyone is interested.
I laid the roof lining down and put the material over it, cut it to size then started from the back and did the worth width of the lining but around a fot at a time.
(23-08-2014, 07:45 AM)Pompey306mark Wrote: I have done about three or four of these trimfix is great stuff and worth using. Go to a local material shop and have a look around you want something nice and thick so the glue goes not come through when you stick it down. I actually have a 5 door one in the garage which I did with brown material if anyone is interested.
Hi I was wondering how hard it is to get the the material around the sun visor recess?
Awesome cheers for the advice. I've been looking at duvet covers for that exact reason, I want some sort of pattern.
http://s48.photobucket.com/user/adammh88/slideshow/306
For those that want to know
I first removed the lights
Then the sun visors and handles
I then pulled the rear pillar plastic down and removed the headliner from the back working forwards as I found it had a lot more glue at the front I struggled Abit near the front seat belts as the trim doesn't move that far the front plastic near windscreen were a doddle then out it came so off to fabric shop see what there is Smile
[Image: imagejpg2_zps9d3eb090.jpg]
A few creases but I can live with that Wink
Nice job, unless you get material with some stretch then creases are unavoidable.
I think there was to much stretch in it I've also painted the front and rear light surrounds Diablo but left handles and sun visors grey unsure weather to do them red or black Idea
[Image: imagejpg1_zps4ce6f90b.jpg]
Sun visors are a bit of a pig, being covered already, theyre hard to cover and cant be sprayed. They can be flocked or replaced with cabriolet visors that ate already black but are slightly shorter.
This was before
[Image: imagejpg1_zps62bb6735.jpg]
Yeah I've been wondering about the visors, mine are stickerbombed at the moment, I don't really like them anymore but can't think what else to do with them!
Piggy flocked my visors and they look great.
(23-08-2014, 09:13 PM)Niall Wrote: Piggy flocked my visors and they look great.
Can the handles be flocked too?
Virtually anything can be flocked
  Fabric for roof lining andyyy 4 4,141 21-08-2015, 12:02 AM
Last Post: Adam-m-h
  Interior light surround thing, on the roof lining? Dean 9 6,873 02-10-2013, 10:36 PM
Last Post: Dean
  Roof Lining And Carpets Toast 8 5,014 11-09-2013, 06:44 PM
Last Post: Grant
