Can anyone recommend any products or methods to getting that squeaky clean and shiny exhaust tip.
Phaes 1 GTI 6 - Onyx Black
Polishing my tip..
12-08-2014, 09:06 AM
1500 grit wet n dry then autosol
12-08-2014, 09:16 AM
As above, autosol....but don't get it confused with anusol...
12-08-2014, 09:56 AM
12-08-2014, 10:07 AM
(12-08-2014, 10:07 AM)silverzx Wrote:(12-08-2014, 09:06 AM)cully Wrote: 1500 grit wet n dry then autosol EFA[/b]
12-08-2014, 02:03 PM
(12-08-2014, 10:07 AM)silverzx Wrote:(12-08-2014, 09:06 AM)cully Wrote: 1500 grit wet n dry then autosol technically so does polish 1500grit is fine, unless they do 2000... either way, that, and a little autosol will do the trick Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
12-08-2014, 02:09 PM
You can get 2000 and finer. It's easy with a polishing head on a Dremel, use it on my inlet.
12-08-2014, 04:34 PM
Degg bought a 2 step metal polish yesterday. Worked really well on my tip.
15-08-2014, 02:14 PM
Does that stuff cut through surface rust?
My tip cleaned up nicely with some 1600 and loob. Just that surface rust/crud
15-08-2014, 10:05 PM
Well deggs tip is covered in soot and that came out nice. Neither of the was rusty tbh.
| Microfibre Car Polishing Cloths | cully | 15 | 6,614 |
08-02-2014, 02:31 PM Last Post: Niall |
| don't leave polishing pads unattended... | lewisdmz | 13 | 7,009 |
13-05-2012, 07:25 PM Last Post: Jacko |
