29-06-2014, 07:04 PM
Cully's Bianca 6 R150 YVM
29-06-2014, 07:07 PM
(29-06-2014, 06:34 PM)ozonehostile Wrote: Is it good that the oil isn't reaching 90? the stat on the oil plate opens at 80c so i guess the oil cooler is effectively cooling the coolant now i know the gauges arn't accurate but that is all i have to go by until i plug planet in but i suspect that wont give oil temp
29-06-2014, 10:32 PM
Looks great in person, can't tell the cooler is there at all
30-06-2014, 06:09 AM
75 degrees on the motorway?? That's not right, time for a new thermostat i should think. As Ozone says, should sit at 90 degrees water temp.
09-07-2014, 06:48 PM
well that nearly ended it all in a pile of bianca bits!
decided to take the car out for a spin only to get the throttle to jam open! ![]() one hell of a brown trouser moment later! after getting it all back together and stopped I lifted the bonnet to find what had happened to find the tiny rubber grommet on the throttle cable had slid down the cable and jammed the throttle butterfly cam open [attachment=17493] not funny..... adrenaline is brown!
09-07-2014, 07:17 PM
Fuuuuuuuuuuuuuuccckkk
I can imagine that being shit scary especially depending on traffic/corners. Alright when your brain realises you can just clutch in and brake but your pants will be brown before then.
09-07-2014, 08:33 PM
Holy smoke cully!!
I bet you were sitting higher in the seat
![]() the smokey old bus that sounds like a tractor...
09-07-2014, 09:03 PM
not one of my favourite moments to be fair
18-07-2014, 11:13 AM
first off I want to say thank you for all the nice comments about my car at pugfest,
I normally pool all the photos I find into this thread but I am not going to do that this year. I will add my favourite photo from the day thank you to all that have taken pictures and have shared them with me [attachment=17799] here is my second hill run also a video of the second hairpin who needs a superchargers hark at that whistle on full chat! and to add to this thread of things done to the car so far I have a list Front brake line flexys front ball joint X2 front Wishbones X2 steering rack gator Handbrake cable O/s Front wheel bearing new s/h Radiator + bottom hose Cam belt +water pump + idlers aux idler pulley New Re-con rear beam New clutch Comp gear linkages Oil+ Filter change fitted strut brace from HDI changed the rear lights to std fixed the Tailgate central locking fixed the N/s central locking re fixed door trims re-glued fabric trims removed cleaned painted inlet manifold plugged resonator reverted back to STD air filter A/C fan switch mod repair battery terminals replaced rear beam mounts (rubber type) renew replace broken arch liners clean off paint under arches x4 clean off paint front lower cross member clean off paint front upper cross member removed black masked fronts returned to std replace gearbox drive-shaft oil seals x2 fitted new front fogs repaired alarm retro fitted RF central locking integrated into existing alarm cleaned up freed serviced 4 x brakes weld repair cracked engine cradle weld chock top engine mount weld repair rebuild drivers seat replace Radiator for new alloy type remove air-con pump + pipework relocate PAS pump into A/c position re-pipe PAS returns weld repair chassis box to outer cill under car replace rear engine mount for vibratec replace rear shocks for B4's replace rear beam mounts for solids replaced exhaust back to STD including CAT + BB replace drivers window plastic clip replace front hubs for 18mm + wheel bearings + BJ's replace track control arm replaced P-bushes for Partner type fit 16 row oil cooler + thermo plate replace O/S rear stub shaft oil filter service
18-07-2014, 12:05 PM
thats one heck of a list...
not sure I would want to make a list with mine....to realise how much I have spent! Wishes for more power...
18-07-2014, 10:35 PM
Car is looking absolutely gorgeous in that picture!
19-07-2014, 11:20 AM
something else to add to the list
have changed the brake fluid for better higher boiling point fluid so brakes should feel good at coombe for the full 15 mins now ![]() bled through the complete system without breaking off any nipples also checked through the suspension and securing points all good ready for its next outing ![]() the old brake fluid was tested and it had a boiling point of 166c the new fluid says 300 + on the tin but is actually 290c DOT4 so a vast improvment [attachment=17809] [attachment=17810] [attachment=17811] [attachment=17812]
19-07-2014, 08:10 PM
Good garages always use floor mats, shows they care about your car
19-07-2014, 08:24 PM
how much is the dot4 per litre these days?
19-07-2014, 08:38 PM
why not Dot5 cully?
I dont use anything else, havnt done for years. For the small extra its soooo worth it! Wishes for more power...
19-07-2014, 09:22 PM
dot 5 is silicon based and not compatible and cant be mixed
dot3-4-5.1 are based on poly glycol compounds. the Dot 4 im using has the highest boiling point available ![]() https://www.opieoils.co.uk/pdfs/tech-art...lained.pdf
19-07-2014, 09:35 PM
cool....the Dot5.1 I use, and always have, has a boiling point of well over 300degrees from memory...not that I would ever explore that!!
But think we probably did on the rally car a few times! you know ya jiz though
22-07-2014, 12:23 AM
what a long day its been
left home today at 15:45 arrived at ACE cafe London around 18:30 around 2 3/4 hrs what a great turn out [attachment=17879] return trip was good but dark with roadworks on the M4 Left ace 22:30 got home 01:00 around 2 1/2 hrs around 80mph all the way there and back used 2/3s of a tank on a 371 mile round trip and the oil cooler has sorted any cooling issues picture is with the car sat on my drive after the 2 1/2hr return trip [attachment=17880]
22-07-2014, 03:52 PM
Good to see its all behaving, this car is lucky to have an owner like yourself.
question is, whats next? From you list earlier on it seems like you've covered most (if not all) corners of the car.
22-07-2014, 04:24 PM
I think he's got to finish that engine he was building.
22-07-2014, 06:15 PM
22-07-2014, 06:22 PM
(22-07-2014, 03:52 PM)mr_fish Wrote: this car is lucky to have an owner like yourself. Exactly that! Awesome to see how far its come.
22-07-2014, 08:12 PM
thanks guys
and another stunning photo just turned up on Facebook [attachment=17917]
22-07-2014, 08:16 PM
Nice pic cully, has the old owner seen it recently or seen it driven in rage
09-08-2014, 03:39 PM
made a purchase in preparation for next years trip to Nurburg Ring
![]() Dynamics Pro race 3's with nearly new Toyo proxies R888 Medium compound [attachment=18297]
09-08-2014, 05:13 PM
You've got too many nice wheels now mate ill have to take some off your hands
09-08-2014, 06:58 PM
White wheels look rubbish on white cars, they'd look much better on my rallye. I'll save you the hassle of posting them and come and pick them up right?
09-08-2014, 07:01 PM
09-08-2014, 07:12 PM
don't argue guys I'm sure we can sort something out
![]() NOT! |
| cully's XU10J4RS | cully | 11 | 10,163 |
30-06-2016, 12:53 PM Last Post: welshpug |
| Cully's Electric car ..T project | cully | 144 | 97,155 |
16-04-2016, 04:14 PM Last Post: cully |
that price is cost price only no markup
![[Image: sig2_zps5d67efb7.jpg]](http://i1133.photobucket.com/albums/m598/rocker8742/sig2_zps5d67efb7.jpg)
![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg)
