22-04-2014, 09:12 PM
My car came with no service history so I'm not sure when it was last serviced. What does a service consist of? So what do I need to buy and do to carry out a service.
Thanks guys
Thanks guys
What's a service consist of?
Thanks guys ![]()
22-04-2014, 09:16 PM
oil
oil filter fuel filter air filter set of spark plugs. probably a good idea to change gearbox oil, brake fluid and coolant too if there is no history. While its all draining, check all the suspension joints, bearings, brake hoses, damper seals, tyres, brake pad and disc thicknesses...if you got drums, whip them off, clean up shoes and adjust them/handbrake cable. (check cylinders too for leaking if you have drums). Top up other fluids, like PAS and windscreen washer, as needed. check all lights check all wiper rubbers. ....make list of things you now need to buy to fix all the things you have found need doing!!!! Wishes for more power...
22-04-2014, 09:18 PM
basic is oil and oil filter change
else depends on milage, and time since last service / history (which you don't know) air and fuel filters are cheap enough to change as a matter of course if you don't know history take all the wheels off and check the condition of brakes / discs / pads / shoes ..etc have a nose around the suspension for any play too while you're at it just give it a good check over really
22-04-2014, 09:19 PM
It depends what level of service it requires. But if you don't have any history for the car, you'll probably want:
Oil & filter Fuel filter Air filter (unless you have a cone, of course) Spark plugs Cambelt kit Water pump Possibly coolant/thermostat change Possibly brake fluid change Possibly gear oil Cambelt adds a fair amount to the bill, especially if you're paying someone. But if you have no idea when it was last changed, then it something to think about. Then everything else you should give a once over, brakes and suspension etc.
22-04-2014, 09:21 PM
(This post was last modified: 22-04-2014, 09:25 PM by Nathan1305.)
Awesome thanks guys
![]() ![]() (22-04-2014, 09:19 PM)Curt Wrote: It depends what level of service it requires. But if you don't have any history for the car, you'll probably want: There's a mobile mechanic that my dad uses and he will fit a cam belt for £40 if I supply the belt. Is this the belt I need? http://www.eurocarparts.com/ecp/c/Peugeo...618&000336
22-04-2014, 09:26 PM
Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference.
22-04-2014, 09:29 PM
(This post was last modified: 22-04-2014, 09:29 PM by Nathan1305.)
(22-04-2014, 09:26 PM)Toms306 Wrote: Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference. Yeah I'll replace them at the same time, if I'm doing the cam belt do I need just the belt or the kit with the tensioner sand stuff? Going to sound like an idiot but is the cam belt also called the timing belt?
22-04-2014, 09:34 PM
(22-04-2014, 09:29 PM)Nathan1305 Wrote:(22-04-2014, 09:26 PM)Toms306 Wrote: Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference. If changing the belt, its advisable to change the tensioners and the waterpump at the same time - if one of those fails it'll mean the belt has to come off again at best....or valves hitting pistons at worst lol. Yes the cam belt is the timing belt. You probably also want to change the auxiliary belt while you're doing that, that's the one that runs the alternator and power steering. ![]()
Get a cambelt kit
22-04-2014, 09:39 PM
Sweet I'll have to replace both when I come to replacing them
22-04-2014, 10:50 PM
Not being arsey or anything cos everyone has to start somewhere and thats what we are here for.
But im sure I read somewhere that you work in a halfords autocenter?
23-04-2014, 07:16 AM
23-04-2014, 07:20 AM
(22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. This would still make no difference... ![]() 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
23-04-2014, 07:49 AM
(This post was last modified: 23-04-2014, 07:49 AM by kentiiboii.)
(23-04-2014, 07:16 AM)Nathan1305 Wrote:(22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. Oh push bikes, I got mixed up with motor bikes :-) (23-04-2014, 07:20 AM)Connor Wrote:(22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. Whys that?
23-04-2014, 07:55 AM
Its a halfords autocenter, that should be obvious
23-04-2014, 09:21 AM
(This post was last modified: 23-04-2014, 09:22 AM by Nathan1305.)
(23-04-2014, 07:49 AM)kentiiboii Wrote:(23-04-2014, 07:16 AM)Nathan1305 Wrote: [quote='kentiiboii' pid='423109' dateline='1398207001'] No worries ![]()
Use the correct, standard NGK plugs for your engine, don't bother with super irridium multi-electrode super-power +999bhp plugs.
Standard NGK will work properly and make the engine run correctly. You don't need anything other than that! It will be significantly cheaper as well. Follow the instructions on the pack on how to tighten them (how many turns until the washer crushes).
23-04-2014, 01:28 PM
If you can find a friend with a halfords trade card for a basic service it works out about £30
oil, oil fiter, plugs, air filter, fuel filter and replacement sump washer.
23-04-2014, 01:31 PM
23-04-2014, 01:32 PM
(23-04-2014, 01:31 PM)Nathan1305 Wrote:(23-04-2014, 01:28 PM)Jama Wrote: If you can find a friend with a halfords trade card for a basic service it works out about £30 Fair enough, though I think on some items the trade card works out as more% off. The plugs I got (bosch) were about £10 and came down to just over £5
23-04-2014, 01:38 PM
(23-04-2014, 01:32 PM)Jama Wrote:(23-04-2014, 01:31 PM)Nathan1305 Wrote:(23-04-2014, 01:28 PM)Jama Wrote: If you can find a friend with a halfords trade card for a basic service it works out about £30 Nice ![]() |
