What's a service consist of? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: What's a service consist of? (/showthread.php?tid=23494) |
What's a service consist of? - Nathan1305 - 22-04-2014 My car came with no service history so I'm not sure when it was last serviced. What does a service consist of? So what do I need to buy and do to carry out a service. Thanks guys ![]() RE: What's a service consist of? - Piggy - 22-04-2014 oil oil filter fuel filter air filter set of spark plugs. probably a good idea to change gearbox oil, brake fluid and coolant too if there is no history. While its all draining, check all the suspension joints, bearings, brake hoses, damper seals, tyres, brake pad and disc thicknesses...if you got drums, whip them off, clean up shoes and adjust them/handbrake cable. (check cylinders too for leaking if you have drums). Top up other fluids, like PAS and windscreen washer, as needed. check all lights check all wiper rubbers. ....make list of things you now need to buy to fix all the things you have found need doing!!!! RE: What's a service consist of? - zx_volcane - 22-04-2014 basic is oil and oil filter change else depends on milage, and time since last service / history (which you don't know) air and fuel filters are cheap enough to change as a matter of course if you don't know history take all the wheels off and check the condition of brakes / discs / pads / shoes ..etc have a nose around the suspension for any play too while you're at it just give it a good check over really RE: What's a service consist of? - Curt - 22-04-2014 It depends what level of service it requires. But if you don't have any history for the car, you'll probably want: Oil & filter Fuel filter Air filter (unless you have a cone, of course) Spark plugs Cambelt kit Water pump Possibly coolant/thermostat change Possibly brake fluid change Possibly gear oil Cambelt adds a fair amount to the bill, especially if you're paying someone. But if you have no idea when it was last changed, then it something to think about. Then everything else you should give a once over, brakes and suspension etc. RE: What's a service consist of? - Nathan1305 - 22-04-2014 Awesome thanks guys ![]() ![]() (22-04-2014, 09:19 PM)Curt Wrote: It depends what level of service it requires. But if you don't have any history for the car, you'll probably want: There's a mobile mechanic that my dad uses and he will fit a cam belt for £40 if I supply the belt. Is this the belt I need? http://www.eurocarparts.com/ecp/c/Peugeot_306_1.4_1999/p/car-parts/engine-parts/belts-chains-and-tensioners/timing-belts/?325545205&1&3cfe5efac76adc50ee77d6972329f1fa0f91c618&000336 RE: What's a service consist of? - Toms306 - 22-04-2014 Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference. RE: What's a service consist of? - Nathan1305 - 22-04-2014 (22-04-2014, 09:26 PM)Toms306 Wrote: Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference. Yeah I'll replace them at the same time, if I'm doing the cam belt do I need just the belt or the kit with the tensioner sand stuff? Going to sound like an idiot but is the cam belt also called the timing belt? RE: What's a service consist of? - Danny2009 - 22-04-2014 Yes mate that's the same belt just different name RE: What's a service consist of? - Toms306 - 22-04-2014 (22-04-2014, 09:29 PM)Nathan1305 Wrote:(22-04-2014, 09:26 PM)Toms306 Wrote: Also change spark plugs with your basic filters service, theyre only £2 each and do make a difference. If changing the belt, its advisable to change the tensioners and the waterpump at the same time - if one of those fails it'll mean the belt has to come off again at best....or valves hitting pistons at worst lol. Yes the cam belt is the timing belt. You probably also want to change the auxiliary belt while you're doing that, that's the one that runs the alternator and power steering. ![]() RE: What's a service consist of? - Curt - 22-04-2014 Get a cambelt kit ![]() RE: What's a service consist of? - Nathan1305 - 22-04-2014 Sweet I'll have to replace both when I come to replacing them ![]() Re: What's a service consist of? - kentiiboii - 22-04-2014 Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. But im sure I read somewhere that you work in a halfords autocenter? RE: What's a service consist of? - Nathan1305 - 23-04-2014 (22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. No I'm a bike mechanic at halfords ![]() RE: What's a service consist of? - Connor - 23-04-2014 (22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. This would still make no difference... ![]() Re: RE: What's a service consist of? - kentiiboii - 23-04-2014 (23-04-2014, 07:16 AM)Nathan1305 Wrote:(22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. Oh push bikes, I got mixed up with motor bikes :-) (23-04-2014, 07:20 AM)Connor Wrote:(22-04-2014, 10:50 PM)kentiiboii Wrote: Not being arsey or anything cos everyone has to start somewhere and thats what we are here for. Whys that? RE: What's a service consist of? - Connor - 23-04-2014 Its a halfords autocenter, that should be obvious RE: What's a service consist of? - Nathan1305 - 23-04-2014 (23-04-2014, 07:49 AM)kentiiboii Wrote:(23-04-2014, 07:16 AM)Nathan1305 Wrote: [quote='kentiiboii' pid='423109' dateline='1398207001'] No worries ![]() RE: What's a service consist of? - RetroPug - 23-04-2014 Use the correct, standard NGK plugs for your engine, don't bother with super irridium multi-electrode super-power +999bhp plugs. Standard NGK will work properly and make the engine run correctly. You don't need anything other than that! It will be significantly cheaper as well. Follow the instructions on the pack on how to tighten them (how many turns until the washer crushes). RE: What's a service consist of? - Jama - 23-04-2014 If you can find a friend with a halfords trade card for a basic service it works out about £30 oil, oil fiter, plugs, air filter, fuel filter and replacement sump washer. RE: What's a service consist of? - Nathan1305 - 23-04-2014 (23-04-2014, 01:28 PM)Jama Wrote: If you can find a friend with a halfords trade card for a basic service it works out about £30 I work for halfords so we get 25% off ![]() RE: What's a service consist of? - Jama - 23-04-2014 (23-04-2014, 01:31 PM)Nathan1305 Wrote:(23-04-2014, 01:28 PM)Jama Wrote: If you can find a friend with a halfords trade card for a basic service it works out about £30 Fair enough, though I think on some items the trade card works out as more% off. The plugs I got (bosch) were about £10 and came down to just over £5 RE: What's a service consist of? - Nathan1305 - 23-04-2014 (23-04-2014, 01:32 PM)Jama Wrote:(23-04-2014, 01:31 PM)Nathan1305 Wrote:(23-04-2014, 01:28 PM)Jama Wrote: If you can find a friend with a halfords trade card for a basic service it works out about £30 Nice ![]() |
