307 Dual Mass?
Right, this is for a mate of mine... he has a 307 hdi with dual mass flywheel...
Basically the clutch n flywheel are done, so I was wondering if it can be replaced with a standard 306 solid fly and clutch?
Which HDi? 2.0 90bhp?
Not sure if it can be done with a 306 1
But when the clutch went on the Mrs 307 Hdi
We put the Conversion flywheel and clutch on it from Euro Car Parts
If i Remember Right it was about £210 for the lot and was easy to change
(05-04-2014, 07:46 PM)R1-Mini Wrote: Not sure if it can be done with a 306 1
Ah right.. did it still drive and feel Ok? Any vibrations or anything?
Iirc it's a hdi 90 yea
They also do a 1.6 90bhp though lol.
As the 2.0 90 is the same engine as the 306 I don't see why you couldn't use a 306 one tbh.
Defiantly a 2.0 it's the pre face lift...
So on that basis then do you rekon the 307 Hdi box is compatible in a 306? For sourcing lower mileage boxes etc
I would've thought so, its just a BE4 'box as far as I'm aware? Ratios are probably different though.
Drove a lot better just like a any other car
(05-04-2014, 08:34 PM)ct-hdi Wrote: Defiantly a 2.0 it's the pre face lift...
307 boxes are different i thought as they are hydraulic and not cable
Although i think they fit as there the same design i dont think you can use because of this??
I think the casings are a bit different
Hmm, are all the 307s hydraulic clutch?
(05-04-2014, 09:08 PM)Toms306 Wrote: Hmm, are all the 307s hydraulic clutch?
Not 100% but the 2.0 hdi's are as far as i'm aware
Ah ok, I didn't realise that.
It will still physically fit, not sure if you convert to manual though (or convert the pedal to hydraulic lol)
could make for an interesting project... another time maybe Smile
  CG Clutch - Paddle Vs Dual Friction pugtk 1 3,346 08-05-2019, 05:17 PM
Last Post: Frosty
  Air mass meter chip? karl1989 28 13,666 05-03-2014, 07:16 PM
Last Post: karl1989
  Dual Mass Flywheel - 306 HDi? Midnightclub 7 6,879 20-05-2013, 04:24 PM
Last Post: Midnightclub
