Do I need to remove my side skirt to take wing off
Could anyone who has replaced a wing kindly tell me if the side skirt needs to come off in order to remove the bottom bolt? and also how are these side skirts held on?
Yes.
You could undo the first 4 or so bolts going back to the rear of the car, but to avoid damage it is best to remove it fully.
Just bear in mind there are rivets that will need drilling out.
no!
i got mine off without fully removing the sill skirt
think i removed the firs two rivets under and the first screw above which left enough room to flex the skirt enough to get the wing out
You must have been lucky then.
Every skirt I have tried that method with has begun to crack under the seals at the base of the door. Old plastic gets brittle with time. Guess yours are in a better way.
My skirts are on with screws which I'm actually happy about
(30-03-2014, 11:45 AM)Grant Wrote: You must have been lucky then.
they were already cracked Wink
If there screwed on just take them off
Team Doesn't own a 306
Ive never removed skirts to get wings off
That's because you come from the far west connor.
Wink
Not really lol im probably the most far east you can get whilst still being in the west country Wink
  Side skirt extensions and rear diffuser side pieces Slam Wagon 38 18,681 19-11-2014, 05:56 PM
Last Post: welshpug
  Side skirt removal Nathan1305 11 8,350 22-06-2014, 10:12 AM
Last Post: Nathan1305
  Door hitting skirt Daniel306 8 4,841 06-01-2014, 04:52 PM
Last Post: Daniel306
