Driver seat issue
Driver seat issue
As said above I have an issue with my driver seat, when you lift the seat up with the little leaver that raises the seat up it stays in place but as soon as I push down on the clutch the seat drops again. Can this be fixed?
Yes, you need to replace the height adjuster handle, common problem. Cheap from a scrap yard though and only held in by a couple of screws.
(09-03-2014, 12:58 PM)Toms306 Wrote: Yes, you need to replace the height adjuster handle, common problem. Cheap from a scrap yard though and only held in by a couple of screws.
Ah okay so even though the handle is in tact it still needs replacing?
  driver's seat bolt's Andrew75 12 6,239 29-04-2016, 05:34 PM
Last Post: Matt
  Patching my driver's seat chylledapps 12 6,034 10-12-2014, 10:48 AM
Last Post: Toms306
  Removing Driver seat Moh 6 3,351 13-01-2014, 09:12 PM
Last Post: Moh
